Thanks Thanks:  2
Likes Likes:  10
Page 5 of 5 FirstFirst ... 345
Results 161 to 171 of 171
Thread: '35 Pro Street Truck
  1. #161
    Huntsville, Al
    Had to blow the dust off
  2. #162
    "The I.E." SoCal
    Sounds Wicked E!
    __________________________
  3. #163
    Aug 2018
    Now that is one beautiful truck! Good job Erik!
  4. #164
    Chino Valley, Arizona
    Sounds sooo nasty!
  5. #165
    Huntsville, Al
    hood scoop 2.0
    here are some Hood 2.0 pics... The Air Scoop seems to drive people away... so... if you pull it off I went ahead and found a "hood scoop" that be bolted "pinched" on the hood to allow for two different looks on the same truck..takes about 20 minutes to swap it out.
  6. Likes erlihemi liked this post
  7. #166
    Loveland, CO
    Eric, what did you use for your running board protection strips, and how did you attach them.
    Your truck is my inspiration.
    Thanks, Ralph
  8. #167
    Huntsville, Al
    they are stainless steel half round bars that we tig welded studs to.
  9. #168
    Senior Member ztoolman44's Avatar
    Apr 2019
    Summerland, BC
    Beautiful build, congrats. If you don't mind me asking, in the end, how does the truck ride with the 4 link? I'm looking to run wider wheels similar to what you have and already have a '94 rear end I can use. I don't mind doing the fab work but I am wondering how the ride would be with a narrowed SN95 3 link versus your setup. Have you had the opportunity to ride in each type?
    Huntsville, Al
    It rode great. No issues
  11. Thanks ztoolman44 thanked for this post
  12. #170
    herb fraser's Avatar
    Looks great ! excellent job !
  13. #171
    Erik
    Just wondering did you change to 4 Link for tire clearance or was there another reason. Planning on building a 35 and planning on Tubbing it Maybe
