0
0
Consummate Learner
Originally Posted by
Jim Schenck
This install is clean, looks good... but then I thought about it... You have to pull the seats, roll bar(s) and waterfall to replace the fuel filter? And how noisy is that fuel pump?
Wouldn't a better placement for both be under the tank? The filter would be easily accessible for replacement, and moving that noisy fuel pump away from the passenger compartment.
So are you able to get the new tank out with the body on?
