I just took out one of the seals and slid the window in and out as needed. Then reinstalled the seal. Or if you have not installed the window stops yet you can just lower it to give room for seal install. Whatever works for you. Doors are the hardest part of the 35 build IMO. Worth the effort though once it is done right.
