Wilwood Pedal Box and Proportioning Valve
So I have the Wilwood pedal box, with 3x 3/4" master cylinders. It includes a balance bar to proportion front/rear brake application. I'm thinking I should install the Wilwood proportioning valve anyways for easier front/rear balance adjustments. So my question is how easy is it to use the balance bar adjuster or should I do both? Who's using both?
