Thread: Front Koni Shock mounts changed?
    slpro1207's Avatar
    Moorpark, CA
    Just starting my second MK4 build and have a question about the upper shock mount. There are two positions to bolt them in that was not on my last build. Anyone know why and which I should use?
    Scott
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    I used the lower holes. There's a note in the manual if I recall that recommends using the lower.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Interesting. The new Coupe has two positions for all the suspension components front and back. Instructions say lower holes for street use, upper holes for race use. I'm building my Coupe as a street machine, so using the lower holes. But the manual says if using the optional double action Koni shocks, they go in the upper holes even when using the lower holes for everything else. Just a flyer here -- but maybe the same thing with the Roadster. Use the lower holes for the standard Koni shocks, upper holes for the optional double action Koni shocks?
    slpro1207's Avatar
    Moorpark, CA
    Interesting. The new Coupe has two positions for all the suspension components front and back. Instructions say lower holes for street use, upper holes for race use. I'm building my Coupe as a street machine, so using the lower holes. But the manual say if using the optional double action Koni shocks, they go in the upper holes even when using the lower holes for everything else. Just a flyer here -- but maybe the same thing with the Roadster. Use the lower holes for the standard Koni shocks, upper holes for the optional double action Koni shocks?
    I believe you are right on the money. I’m using the lower holes. BTW I am really enjoying your new build thread. I learned so much from your MK4 threads. You have saved me from numerous headaches and pitfall, and I’m sure it will be the same with the 65 coupe I plan for my next build.
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    I did the same for the front (standard Koni's).
    I assume this is the same for the rears (new MK4 frames have two sets of holes) ?
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    Jan 2018
    Also - it looks like your ball joints are pointing the wrong direction in your picture, the threaded part should point outward. Edwardb pointed out on my build that the UCA's need to be disassembled and have the mount they screw into flipped.
    O'Fallon, MO
    Quote Originally Posted by JoeAIII View Post
    Yes thats correct. Good catch, didn't see that till you pointed it out.
    slpro1207's Avatar
    Moorpark, CA
    Yeah, I caught that yesterday when the spindle just would not line up. I can honestly say now that Loctite works very well. Nothing a small torch heating everything up couldn’t fix.
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Gentlemen,
    Reading this sparked my interest, my front and rear red Koni's are installed in the upper mount holes. Did I miss something in the manual? FFR told me they won't fit there but they do! Is it detrimental to the car's handling performance? I plan on changing to the correct location but I'm curious of the impact!
    jim
