Thread: Front Fender support bar?
    lower front fender support arm?
    I am not sure if I have the right part here?
    The lower front fender support arm (818c), according to the manual has a twist to it. I have two straight bars (cleaned up and painted black in the picture). However, there would need to be a bracket or something needed at either end to make them fit.
    Am I trying to configure a wrong part here?
    Sep 2015
    Hamersville, Ohio
    Looks right, you will just need to put a twist on it. Heat helps that. No real advantage as to where the twist is. Prolly close to one end would work well.
    Leesburg, VA
    I put one end in a vice and twisted the other with channel locks, worked fine. A shop rag on both ends will help protect the paint.
    Thanks for the quick replies!
