Results 1 to 40 of 54
Thread: SCNS 02/2014 MK4 Coyote TKO500 8.8 IRS BT
Hybrid View
    Jan 2018
    Sarasota, FL
    Hello all,
    Starting our shop dust collector project. Its a MK4 Roadster chassis with a 2/2014 build date. So as you can imagine we are slightly past our 45 day grace period. Any how should be a fun project, plans have switched to a 5.0 Coyote drivetrain. Just started going through our checklist for parts, and front suspension is in the works. More pictures to come soon.
    cobra.jpgthumbnail (3).jpgthumbnail (4).jpgthumbnail (1).jpgthumbnail (2).jpg
    Dec 2017
    SW Fl
    Greetings,
    Haven't started my build yet, but after reading through some of the others, this family will be 200% alongside you as you progress. Best of luck, I will enjoy following your build and there are many solid friends here to share and rely on...
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Welcome aboard! Sounds like you have a plan, keep the pics coming.
    Kyle
    Jan 2018
    Sarasota, FL
    A plan for sure, 5.0 Coyote/Tremec TKO 600 edited (600ft/lb tq. rating sorry)/ 8.8 Ford 28 Spline Trac Lock. Which were ordered yesterday, waited to do so until we actually started on the project.
    MKVIII IRS Housing which I will be Powder coating
    Internals from the 97 MKVIII IRS Donor car
    Rear hub/spindal coated new bearing/studs installed to match front. Axles, upper/lower tubular controls, coils-overs to be replaced
    Pictures of our ditched Motor Already has a new home, so no worries.
    Sep 2011
    Minneapolis, MN
    Welcome and thanks for sharing. I used the same approach of harvesting housing and spindles from a MKVIII. You look like you know what you're doing which is more than I could say for my own skills when rebuilding the center section. All good now though. Center section is in place along with the rest of the rear suspension.
    Lots of help on here for any detailed problems you run into. Good luck!
    -- John
    Jan 2018
    Sarasota, FL
    Quote Originally Posted by John Ibele View Post
    -- John
    Umm maybe, not my first 8.8 I have rebuilt. But it is the first I have fitted a Trac Lok into one. So shims should be fun. The kit which will be here tomorrow.
    Here are some more pictures of today's work, again waiting on the diff to finish up.
    Diff housing coated
    Separating the ring gear from the carrier, all bearings removed.
    New Races for pinion bearings pressed in.
    New oil slinger seal seated.
    Flange, pinch ring, leading pinion bearing.. all installed and ready to be tq'ed to 22in/lbs deflection/resistance.
    Junior Member Clark L Creswell's Avatar
    Jan 2018
    Melbourne , Florida
    Welcome from Melbourne Florida , looking forward to watching your build .
    Clark
    Jan 2018
    Sarasota, FL
    Quote Originally Posted by Clark L Creswell View Post
    Clark
    Yeah I need to have it moved over to the proper "build thread" forum here shortly lol.
    wallace18's Avatar
    Trenton, Florida
    Nice to see another Florida builder have some fun. I am up in Alachua, FL. PM me if you ever have any questions. I am always happy to help if I can.
    Jan 2018
    Sarasota, FL
    Appreciate it, located in Sarasota, FL, so a bit south of you I believe. And will do.
    Jan 2018
    I just ordered my 65 coupe here in Clearwater, FL. Still 30+ days away.
    Jan 2018
    Sarasota, FL
    Quote Originally Posted by Wilder View Post
    Waiting is the hardest part, lol. Trust me.
    Port Charlotte, FL
    Welcome to the madness. I am located in Port Charlotte and have a Gen III about 80% complete and a Mark IV complete that I drive as much as possible. If you have any questions or would like to stop by, please PM me.
    Thx,
    Henry
    Member cwhoofgator's Avatar
    Orlando FL
    Make sure and join the Deep South Cobra Club when complete. We have a lot of fun with these things..
    Currently re-building FFR5066K 5.0 T5 3:55 four link.
    mcwho's Avatar
    DeBary - Florida
    Quote Originally Posted by cwhoofgator View Post
    Thought I would chime in here, also in Florida, halfway between Orlando and Daytona. I will make on of the DSCC events eventually.
    Baghdad Bob
    Jan 2018
    Sarasota, FL
    Quote Originally Posted by mcwho View Post
    Cool, I passed through there a few weeks ago for the Rolex 24HR Daytona race. Those are always fun.
    Jan 2018
    Sarasota, FL
    Building the diff
    This finally showed up today, I really am not happy with my Fedex over night service here, 10AM garenteeed, haha ok.... bunch of extra money for 3 o'clock delivery. Any ways, new 8.8 IRS Trac Lok.
    Vs. the old carrier and slippage.
    OEM Ring being seated
    Tourqed to 90ftlbs. with blue locktight
    Starting on bearings
    Jan 2018
    Sarasota, FL
    Also finally seated the crush ring for the pinion...it was way more difficult to get it to 20in.lbs/2.2nM of resistance then I thought it would be, but its there.
    Hard to see it because of needing to keep it moving to read.
    Jan 2018
    Sarasota, FL
    All together ready for install once the lubelocker gasket comes in new vent tube and new flange bolts for the driveshaft.
    ALso got the tank assembled and installed, thinking about reworking the mounting of said tank as Im not completely happy with how its mounted.
    Quote Originally Posted by SelectivePC View Post
    Also got the tank assembled and installed, thinking about reworking the mounting of said tank as I'm not completely happy with how its mounted.
    Your build is looking good!
    The tank will fit much better if you flatten the flange around the center. Those bends for the tank straps need to be removed. Then it will fit like it's supposed to. Mentioned in the build manual, but many miss it.
    Jan 2018
    Sarasota, FL
    Ill have to look into these bends your talking about, and flange. Thank you.
    Looking at my post, flattened would be a much better word than removed. Don't want to give the wrong idea. No material is removed. I use a large adjustable wrench and pinching the metal, slowly/carefully work the flange back out to flat and level at the four locations it's bent. There is a weld going through those areas between the top and bottom halves. So you want to use some care. But I've never had any issues afterwards. Check the build manual for the fuel tank installation and you'll see this mentioned and maybe even pictured. You want the flange to sit flat on the four plastic cushions in the frame. It won't with the bends still there. I think you'll find it actually fits quite well.
    Jan 2018
    Sarasota, FL
    OK, I understand now, easy enough. Tomorrow it shall be done.
    Jan 2018
    Sarasota, FL
    Little update.
    Hey guys, been busy around the shop, so I have been slaking on build updates, but more parts are on the way currently so been killing time with mustang things.
    Few customer cars we worked on,
    VMP TVS supercharger and billet oil gear install 2017 Mustang 5 speed car.
    2018 Mustang Single Turbo kit 10R80 Auto trans, this one is going to be a lot of fun (sorry for picture size trying to keep things under wrap till we do more testing)
    Jan 2018
    Sarasota, FL
    Anyways back to the MK4 just a few things here and there.
    Holes drilled.
    Started removing the floors to start on them this week, hopefully.
    And more rear-end goodies, hope to install that sometime this week as well.
    Jan 2018
    Sarasota, FL
    So come to find out the rear hubs from a Lincoln Mk8 are different from the standard IRS hubs from a foxbody. The kit is from 2014 and just getting started on now, but wasnt noticed untill now, FFR has a revised kit available currently. So these were ordered to fix the problem and installed today.
    Bolt Pattern difference, whoops
    All done
    Next up is to properly fit the gas tank noticed by edwardb, and install the diff while im down there, Should be fun by myself
    Jan 2018
    Sarasota, FL
    Home sweet home. Only nicked the powder once on the bottom. Easy touch up.
    Jan 2018
    Sarasota, FL
    Good evening lady's and gents. Small update, tank is in its finally placement. Did a little research and our small 1x1 plastic plugs were not shipped in our kit. But easy enough and i'm sure these little rubber spacers will do the trick.
    Sits up and way closer to the frame now, and is a whole lot more solid feeling, doesn't move a bit. Thanks again edwardb.
    So tomorrow starts the brake lines, found a pretty good write up on them, shouldn't be too difficult.
    Dec 2017
    SW Fl
    Selective, Nice work. That IRS looks sharp in there. I recall an earlier post regarding the IRS and rear battery box issues, have you made a decision as to front or rear batt install?
    Jan 2018
    Sarasota, FL
    Quote Originally Posted by SerpantFL View Post
    Thank you sir, Not as of yet, but we are a dealer for Braille, so i'm sure wherever we decide to place it, its not going to be a problem tucking it away somewhere. I have seen a few threads of people mounting Optima batteries up in the front, so that may be an option. Otherwise I can just adjust the mounting from the manual.
    Jan 2018
    Sarasota, FL
    Rear brake lines completed.
    Hello All,
    Finished the rear brake hard lines today. Not too difficult after looking through edwardb's brake install. Tried to follow it as much as possible, as he did a super nice install. Couldn't get as tight of bends with my tool, but they don't look horrible for a basic Harbor Freight bending tool, Better tools are ordered and on the way. Any who, here's a few pics.
    Dec 2017
    SW Fl
    Don't knock yourself, I have used cheap tools also and had less success. The lines came out well even though they may not look factory to you. I bought a Rigid tubing bender after many tries at it with a lesser tool. You can shine with the fuel lines...
    Jan 2018
    Sarasota, FL
    Fortunately enough we are using a 5.0 Coyote motor so a larger pump and AN lines will be used for this setup. So just routing them will be needed.
    But I was thoroughly impressed by how well they can be hid, and after seeing how EdwardB did his, I was able to get it knocked out.
    Looking good. Worked on brake lines myself today on the Coupe build. One thing I notice from your pictures. You have the older style Factory Five clutch cable mod for the Wilwood box. I hate to be the one to tell you this, but that one has been troublesome. To the point where they redesigned it. Instead of being offset and putting side load torque on the pedal and pivot that it was never designed for, the new version fits directly over the clutch pedal and pulls in line with the pedal and pivot. It's shown in these newer instructions: http://www.factoryfive.com/wp-conten...ILWOOD-NEW.pdf. In addition to obtained the newer parts, you would need to move the hole for the clutch cable over. Something you may want to consider. Relatively easy to do now. Wouldn't be fun to fix the current one or try to install the new design once your build is finished. Maybe some others have opinions about whether it's worth it to change. I've only used hydraulic on the Wilwood pedal box, so I'm far from an expert on the subject. Only know about the reported failures and the redesign that's been standard on all kits for several years.
    Jan 2018
    Sarasota, FL
    I have seen a different type of over the pedal your talking about. Still up in the air on if we want to use a Hydraulic or cable. Worst case we will just get the update over the pedal version.
    On a side not, I didn't realize the motor we received earlier this month, wasn't actually for this Cobra, it was for another one of our resto mod projects. A 66 Mustang I believe.
    Another 5.0 motor out of a F150 long-block for the MK4 will arrive this week sometime. Along with a Holley EFI ECU and wiring system, Holley heads up display, GPS, and Cam controller. Surprisingly, they had an overstock sale through our main vender (Turn14) for the set up. Ended up being cheaper to do this then too buy a motor set with the harness and pcm pedal set, blah blah.
    https://www.holley.com/products/fuel...parts/550-618N
    https://www.holley.com/products/fuel.../parts/553-106
    https://www.holley.com/products/fuel.../parts/554-140
    So it'll be like Christmas this week. Cant wait.
    Jan 2018
    Sarasota, FL
    Front brakes and motor.
    So the cobras motor has finally made it too the building. Now need to order a oil pan, forgot about that little detail.
    Also finished up the front brakes, ended up having to make some brackets, as the second set were not in the kit. Not too difficult.
    All better
    Again trying to follow EdwardB's brake line set-up. Not perfect, but not horrible.
    Not being able to make that tight of bends again, had to make this contraption.
    Jan 2018
    Sarasota, FL
    Brakes before
    After coating
    Jan 2018
    Sarasota, FL
    So resealed front timing cover, installed billet oil pump gears, and back together, ready for an acid bath and paint. Owner wants the motor painted like an older Ford motor, so that's the plan I suppose. May look weird, but too each their own.
    Also goodies have started to arrive, cant wait for everything to show, but I can continue on the plumbing of fuel lines now so i'm happy.
    And we have a brian box and harness as well. Super nice wiring if anyone is interested in Holley Dominator stuff in the future, looks too be a super easy to read harness.
    Jan 2018
    Sarasota, FL
    Need to do a bit of research on the oil pan and pick-up sets the other guys are using, and also the motor mount situation, as the used motor company pulled or motor mount brackets and mounts. *******s.
    I have seen a lot of the Moroso's used, but don't know if there is a difference in them. So time to start googleing.
    The Moroso setup everyone is using with the Coyote is a Moroso 20570 pan with Moroso 24570 pickup. I'm not aware of another brand option, although maybe there is one.
    For motor and transmission mounts, the common setup is the Energy Suspension 4.1127G 4.6L Mustang Motor Mounts and the Energy Suspension 4.1104G Transmission Mount. You'll want to add the 1/2-inch spacers that Factory Five makes for inside the motor mounts. Part of their Coyote installation package. But available separately.
    Couple of other points. Looks like an F150 Coyote? That oil filter orientation is different than the Mustang, and as I recall that's one of the differences. Regardless, the oil cooler won't fit and probably you'll need to turn the oil filter or use a remote. Also, since you do have an older kit, I'm assuming you still have the older style footbox aluminum? A lot has changed since then for Coyote installations. Factory Five used to use sheet metal that also was for the older 4.6 mod motor. But it's an interference fit for the Coyote unless you tip the engine over, plus it takes a big bite out of the footbox space. There is newer sheet metal that fixes both. Gives room for the Coyote plus restores the lost footbox space. This was recently discussed in another forum post, so maybe you saw that or already knew about it.
