Sometimes I have thought of sticking the wood steering wheel on, in place of the leather one, just for a change, or perhaps for a show and shine.
I was thinking the fast and simple way to do this, was to have a second boss, which I could leave attached to the wood wheel. Then it would be a simple matter of popping off the badge center cap, and unscrewing one bolt from the column. Simply reverse the procedure with the other steering wheel.
I wondered though, if the current boss, is actually the same screw hole pattern as my MK3.1 steering wheel hub? I worried this might have changed, when the MK4 came out?
Can any member confirm if it's the same, or not?
Thanks, Bill
