Results 1 to 5 of 5
Thread: Steering wheel boss
    Steering wheel boss
    Sometimes I have thought of sticking the wood steering wheel on, in place of the leather one, just for a change, or perhaps for a show and shine.
    I was thinking the fast and simple way to do this, was to have a second boss, which I could leave attached to the wood wheel. Then it would be a simple matter of popping off the badge center cap, and unscrewing one bolt from the column. Simply reverse the procedure with the other steering wheel.
    I wondered though, if the current boss, is actually the same screw hole pattern as my MK3.1 steering wheel hub? I worried this might have changed, when the MK4 came out?
    Can any member confirm if it's the same, or not?
    Thanks, Bill
    They are all the same. I wouldn't do it though. If properly seated, it doesn't come off easily. And every time you take it off you wear it out a bit. I would just remove the screws holding the wheel to the adapter.
    Another option would be to go w/ a quick release hub and have one for each wheel.
    http://www.breezeautomotive.com/deta...=413&cat_id=12
    http://www.breezeautomotive.com/deta...=432&cat_id=12
    Not inexpensive though.
    So Mike you mean the splines on the boss wear with removal?
    Craig, those are pretty expensive, especially for two of them! I like the concept though.
    Probably have to lock the wheel in the trunk, if I left the car on it's own, or risk having someone keeping it as a souvenir..
    Quote Originally Posted by AC Bill View Post
    I put mine on to go-kart my car right after first start. When I went to remove it to install the Russ Thompson turn signal mod I had to use a puller. I'm not putting it back on until I don't have to take it off again.
    Mk4 #8866
