Looking for pic of radiator position
Since I don't have the grill, I need another way to find out where to put the radiator.
If anyone has final fit done, can they measure distance or post picture of relationship between "F5" steel bracket and aluminum radiator tab, or between lower chassis and bottom of radiator?
The closest pic I've seen is this one from tcollins, but even here it's not at the right angle to be sure of the distances involved. I know it's not that important and I could "put it where I want" but I'd like to be close. It looks like the lower chassis lines up pretty well with that weld on the bottom tank..
Attachment 80250
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
I found one, thanks to Michael Everson's pic of his nice-looking radiator shroud. It shows all the holes I need to put the radiator in position.
http://www.replicaparts.com/Hot%20Ro...oud%20page.htm
build thread
