Thread: Need help with Rear Brake Caliper
    Jul 2017
    Can anyone tell me how to install the two clips at the bottom of the picture? Want to make sure
    I get this right. Thanks, Don
    Jan 2018
    They go on either side of the bracket where the tabs on the side of the pads ride in them
    They are anti rattle clips and keep the pads from rattling against the bracket there by applying a little bit of pressure on the guide tabs
    Jul 2017
    Thanks! That helped me figure it out. Don
    Nov 2016
    Petaluma, CA
    Can someone show a picture of their installation?
    Unconventional Builder Joee's Avatar
    Hatboro PA
    Quote Originally Posted by japollon View Post
    Go here
    https://turn5.scene7.com/is/image/Turn5/386333?$enlarged810x608$
    Roadster Mk3 5294, 302 Comp XE276HR cam, AFR 185 heads, 650 Quick fuel carb, Air Gap intake, T-5 3.55 gear Levy Upper & Lower Front and Rear control arms Purch Jan 2008 Tagged Mar 2012 Best ET 12.14 @113** SOLD 4/8/18 **
    YouTube Videos: Current performance - https://www.youtube.com/channel/UC7c...86xO3U4l4RtVMQ Older build - http://www.youtube.com/user/joeembery#p/u My Pics:
    http://s207.photobucket.com/user/Joe...?sort=6&page=1
    Aug 2017
    Southern WV
    I’m not sure if this will help
    Tex
    If you are building a complete kit with the willwood petal box and the Ford GT brakes front and rear I would replace the stop tech brake pads with a more aggressive pad
    The stop tech pads require a LOT of pressure to lock up the brakes and make a lot of brake dust
    Several vendors made a more aggressive pad I installed EBC blue stuff pads and they made the car have a lot better brake response
    Hope you have a great time building the car
    Rick
