Results 1 to 4 of 4
Thread: Steering Wheel Center 289 FIA
    Nov 2016
    Petaluma, CA
    Does anyone know the origin of the center piece on the steering wheel in the picture below? This appears to be an original 289 car and I am wondering if this piece is reproduced by anyone or maybe available as a part of another steering wheel package. More than likely I am paddling upstream on this one!
    Joel
    Elk Grove, NorCal
    Hi Joel
    That is an early model cobra which had the worm and sector gear steering which was inherited with the chassis from AC Cars. Shelby later changed the steering to rack and pinion which most of the newer cars replicate. Ive never seen a replica with that style wheel...but then again, im not near an expert on these things.
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Nov 2016
    Petaluma, CA
    Thanks so much! You know way more about it than I do. I just liked the period correct look. I'm sure it's no longer available.
    Sep 2015
    Beachside
    Hi Joel,
    Try Nick Acton at Acton Custom Enterprises. He may make something or know of a source.
    FFR #8833 289 FIA 3-link
