So I have a few miles on the Hawk Coupe and I have noticed that the air does not really flow into the cockpit.... what do the A-pillar deflectors that I see on other coupes do?
Pete Brock designed them to channel air along side of the cabin so the side scoop could have air supplied to them.
Basically the A-pillar deflectors will allow air to be direct along the side of the body, where the natural tendency
of the air is to break the boundary layer adhesion, and swirl off the side of the cabin. So you will have an improvement
of the air passing along you window. Contact Russ to see if he has any pairs in stock. they're stainless and well made/
Hank
Yeah, they direct air to the scoop right into your cabin. Will provide a little extra circulation for cooling if you have no air like me. I also made my side windows removable, take out time, 3 minutes per side, reinstall, under 5. I've driven in 90 degree + temps and survived it about the same as I did in my convertible whe it had the black top up.
We put our windows in to stay. We have Russ' opening rear windows and the pillar slats in addition to the normal brake duct scoop. (no ducts) It is livable up to 95ish degrees while driving, just don't get caught in traffic. If you aren't installing side windows, consider rolling the slats a little farther around the pillar so they shove the air in. They would probably hit the door windows if you put the slats on that way.
Coupe 0652 408 Windsor 510 hp TKO600-68OD 3.73 Traction-lok A/C and heat, Guardsman Blue with White stripes picked up 9/14 first start 7/10/15 go kart 8/15/15 registered, painted (body-on) 11/12/16 inspected and on the road 4/20/17
At these A pillar deflectors custom of off the shelf somewhere?
Just to add I don’t know who built this car but this is my muse
P100DHG’s Gen 3 65 Coupe #138 Build Thread - Order Date: Aug 2018 - Delivered: Feb 2019 -
First Start: May 2020 - First Drive: January 2021 - Instagram @SixtyFive_Daytona
Russ Thompson used to make a VERY nice set but no longer does. It’s now a custom option. There are lots of pictures out there of them. One small detail I hadn’t noticed before was that, in 1964, they were mounted on the doors. Later they were mounted on the body (which means they have to be mounted such that the windows clear them when the doors are opened). I sketched the brackets out (I’m pretty sure that I bought the last set that Russ made) and have sent the templates out to a couple other guys. If you send me your e-mail address I can try sending them to you also.
George T
Type 65 Coupe #338, Picked Up 4-Aug-07, Roller on 8-Mar-09, 1st start 8-Sep-13, 1st Autocross 7-Oct-18, finished sanding & sprayed paint myself 6-Nov-21, IRS/LCA/Koni/traditional gages/Kirkey/pin-drive rear width/15" Torq-Thrust Ds/44IDFs/Brodix ST5.0R heads/Eagle internal-balance crankshaft/oil pan by Armando/home-made turkey pan/S-10 mid-shift T5
