Thread: Lower Control Arm Bolt towards front of car
    Jun 2017
    Anyone know what bolt to use for the lower control arm where it mounts towards the front of the car. There is one per side.
    Glenn Rathke
    Feb 2013
    Westminster, MD
    Use the OEM bolt.
    Jun 2017
    Use the OEM bolt.
    Thanks for the info. For some reason I do not see the size, spec or part number of the bolt. Hopefully, I will be able to post the part as I ordered it from Subaru.
    Glenn
    Feb 2013
    Westminster, MD
    They don't list sizes but here's the part number for the bolt:
    https://parts.subaru.com/p/Subaru_20...901000264.html
    and the nut:
    https://parts.subaru.com/p/Subaru_20...902350006.html
    Jun 2017
    and the nut:
    THANKS for that info.
    Quote Originally Posted by grathke View Post
    Glenn Rathke
    Bolt, M12x1.25x 90 LCA front mount
    Nut, M12x1.25 LCA front mount
    Below is my whole list for the lower control arms
    2006 Donor Front lower control arms Steel (1pair) 1 EA
    80267 box 1 FRONT LOWER SHOCK MOUNT BRACKET. WELDED STEEL 2 EA
    80500 box 1 LOWER IFS BRACKET NUT HOLDER, WELDED STEEL 2 EA
    25662 box 3 BOLT, M10X1.5MMX35MM Shock Mount 2 EA
    80356 box 3 BOLT, M10X1.5MMX40MM Shock Mount 2 EA
    2006 Donor Bushing Back of Lower control arms right 1 EA
    2006 Donor Bushing Back of Lower control arms left 1 EA
    2006 Donor Bolt, M12x1.25x 90 LCA front mount 2 EA
    2006 Donor Nut, M12x1.25 LCA front mount 2 EA
    2006 Donor washer, back bushing 2 EA
    2006 Donor stopper rubber, rear back bushing 2 EA
    2006 Donor stopper rubber, front back bushing 2 EA
    2006 Donor nut, self locking M14x1.5 back bushing 2 EA
    2006 Donor Bolt, Hex M14X1.5X50 -10.9 mount bushing 4 EA
    MMC Washer, M14 - Hardened Flat 8 EA
    BelMetric Nut,M14X1.5 - Class 10 Nylock mount bush 4 EA
    Jun 2017
    Thanks for the parts listing. It is a huge help.
    Glenn
