Results 1 to 4 of 4
Thread: Do I re use this pinion flange?
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    I took this off my 8.8 straght axle. Do I re use this flange, do I need to get a different one, or does one come with the kit?
    Thanks!
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
    reuse it
    In case you need any, here are some instructions on the 8.8 rear end. (You'll need an in/lb torque wrench for figuring out the pre-load, after replacing the crush washer).
    https://performanceparts.ford.com/do...htM-4209-8.pdf
    Jul 2012
    Kearney Nebraska
    reuse it
    Thanks! I will.
    Quote Originally Posted by AC Bill View Post
    Those are good instructions. Thanks!
    Serial #9158
