I’m trying to install FFR brakes onto rotor. Left side went great but right won’t go over rotor. I have determined that the piston is pushed out slightly causing the pads to be to close together. However the piston will not move in at all. I used a little bit of air and it moved smoothly out but will not slide in. Also I removed the bleeder valve. This is the FFR standard brakes on the IRS. Any suggestions?
