Thread: New caliper piston not moving
    slpro1207's Avatar
    Moorpark, CA
    I’m trying to install FFR brakes onto rotor. Left side went great but right won’t go over rotor. I have determined that the piston is pushed out slightly causing the pads to be to close together. However the piston will not move in at all. I used a little bit of air and it moved smoothly out but will not slide in. Also I removed the bleeder valve. This is the FFR standard brakes on the IRS. Any suggestions?
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Santa Clarita, CA.
    The rear brakes take a special tool to screw in the piston.
    I use the cheap tool in this video. Make sure to just go to flush and line up the slots.
    https://www.youtube.com/watch?v=4p6jjvULrP0
    This explains it a bit better.
    https://www.youtube.com/watch?v=hQfV0b75hgI
    I assume they are the rears? Are they Wilwoods? If so read PhileasFoggs thread. He sent his calipers to Wilwood because he had actuated the park brake a few times.
    slpro1207's Avatar
    Moorpark, CA
    Quote Originally Posted by CDXXVII View Post
    The rear brakes take a special tool to screw in the piston.]
    Thank you. I have rebuilt calipers in the past. Long long time ago. No special tool required.
    Quote Originally Posted by slpro1207 View Post
    If you're working on a Ford rear caliper and the piston won't return with the bleeder screw removed...
    You need a special tool.
    https://www.youtube.com/watch?v=rlMU8K36Hjo
    Lost Wages, Nevada
    Having worked on thousands of FORD brake systems as a FORD mechanic, the rears need a special tool to "screw" the piston into the caliper bore BECAUSE of how the park brake functions.
    I have this very affordable set that I bought on Amazon:
    https://www.amazon.com/Caliper-Compr...per+tool&psc=1
    It allows you to compress caliper pistons and "wind" the ones that require it.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
