Results 1 to 13 of 13
Thread: coyote won't start
    Nov 2016
    coyote won't start
    Ready for first start and nothing. Fuel pump isn't coming on so I checked the voltage, 2.22 volts. Why would it only have 2.22? I can understand 0, or 12, but how does it get 2.22? Tried an alternate ground, same thing, 2.22.
    Nov 2016
    "The i.e." SoCal
    Did you wire around the Ron Francis fuel pump relay?
    Nov 2016
    Well, followed the coyote manual of wiring the green coyote fuel pump wire into the tan wire in the rf harness bypassing the relay in the fuse panel.
    Raleigh NC, OIB NC
    Internal or external pump?
    Kevin
    MKIV #8234
    Nov 2016
    internal
    Mine did the same thing. 2.2
    I had connected the leads to my Malfunction Indicator Light backwards and that was enough to give the PCM a signal it did not like so no power to the fuel pump.
    Ford figured the odd power reading was a ground issue so I re routed all of my grounds and still got 2.2.
    Double check our connections and grounds. Hopefully yours is just that simple.
    Quote Originally Posted by Royteamcobra View Post
    You should bypass the fuse in the RF panel, but not the relay. The relay is used for the inertia switch, which I hope you're using.
    The power and fuse protection for the in-tank fuel pump with the Coyote setup come from the Coyote PDB. If there isn't +12V on the Coyote PDB fuel pump wire when the key is turned on, then something is wrong with the wiring and the PCM isn't powering up the line. Could be the MIL as mentioned. Could be the ignition sense wire. Check all the wires.
    Norton, MA USA earth
    Not sure about the 2.2 volts but I just had the same problem. I accidently swapped the IGN and ACC on my ignition switch. This mistake would shut off the fuel pump and start request while cranking the engine.
    Nov 2016
    Thanks for the tips, I was hoping it was going to be an easy one to find but no such luck. Ill keep checking every connection again. I am using the digital dawg keyless ignition, and might be an issue with that.
    I would be inclined to temporarily remove the Digital Guard Dog module and confirm your Coyote installation works with a traditional ignition key. There's just a few wires and wouldn't take long. Once that's working, either as is or with further troubleshooting, then focus on the Digital Guard Dog installation knowing your Coyote itself is wired correctly.
    Fairfax Station VA
    DGD requires a solid ground; make sure it's got a good one. If you're sharing the DGD ground with other stuff, I suggest you separate them temporarily, using a temporary jumper to determine if separate grounding helps your problem.
    MK IV Roadster #8631
    Nov 2016
    Well, maybe someone more familiar with the coyote systems can figure this out. For two months I've been trying different things to get this started. Removed the push button start, went to the included switch, continuity tested all grounds, added extra motor grounds, tested voltage at each connection, changed positive connection on MIL, never could get power to the fuel pump. Finally directly wired pump to the battery just to test the pump and get some fuel through the lines into a bucket to purge the line in case any junk in there. Worked fine. Hooked up the fuel line back to the motor, turned it over again just to show my son the motor was turning over.... And it fired up! I have no idea what finally caused the pump to get power. Anyhow, it's running now! Next try to hook back up the push button start.
    Nov 2012
    Tacoma, WA
    Congratulations glad you figured it out. At first I had the roll over switch activated myself, but quickly figured it out.
