0
0
Tandem master cylinders have a volume ratio, usually 2:1, with more fluid going to the front. In the normal position, the front port goes to the front brakes. Hot rods like mine with an under floor mounted MC have the MC pointing backward, so the back port goes to the front.
http://www.wilwood.com/MasterCylinde...o=260-14241-BK
Originally Posted by
DaveS53
lol - that seems certain to cause some confusion...
DaveS53
True - a better wording would be more (circuit) volume is (usually) allotted to the front calipers.
This is the rear circuit on the OP's MC and installation.
Not a waxer
DaveS53
The OP told us that he has a '95 Cobra master cylinder Dave. Your statement that the front port goes to the front brakes is wrong.
Jeff Kleiner
Wouldn't be the first time. I just assumed a Wilwood MC from the looks.
