ReinCarNation
Results 1 to 2 of 2
Thread: Radiator fan wiring question
    Need help in clarifying the radiator fan operation.
    1. Am I correct that 1 fan is cooling and 1 fan is for AC?
    2. If #1 is correct are you wiring them both together to run at the same time?
    3. Is there any difference in the fan operation as I am running a JDM EJ207 and JDM ECU?
    Aug 2017
    For question 1:
    The fan setup only turns on the fans as needed first the primary, then secondary. The AC puts a higher load that tends to kick on the secondary fan
    If you look down a few replies there is a chart for fans coming on.
    http://www.subaruoutback.org/forums/...-wont-run.html
Clever Turn Signal
