Results 1 to 7 of 7
Thread: Brake Bleeding and Wilwood master cylinders
    Jun 2017
    I am at the point of bleeding my brakes. I am using the Wilwood pedals/MCs with a Tilton remote reservoir. For the life of me I cannot get the plastic top to seal against the master cylinders... Every time I go to bleed the brakes I am sucking in air.
    Anyone else run into the same issue?
    Bowling Green, KY
    I have the same set up and didn't and don't have a problem bleeding the brakes. What I did have a problem with was getting the banjo fittings to seal up on one of the masters.
    Jun 2017
    Banjo... Mine don't have banjos.. the lines go in the front with an adapter for the NPT to flare... Must be a different model. I will mess with it some more..
    Thanks!!
    Jun 2017
    Ok.. so tried to bleed them and it just leaks from black cap that has the hose.. not even enough pressure to bleed them...
    Atlanta, GA
    Do you have the wormdrive clamp on the cap?
    Jun 2017
    Sure do and the o-ring in there too..leaks like crazy trying to bleed the brakes
    Jun 2017
    Ok.. so I’m a dope.. I had the o ring in the wrong place... works like a champ now!!!
