Will donor spindles attach to the Factory Five upper/lower control arms? Spindles are 99-04
Thanks again,
Higgy
Thanks again,
Higgy
Short answer yes. With the required upper ball joint adapter. http://www.factoryfiveparts.com/1381...apter-bracket/. That spindle is also slightly wider than previous versions. About 3/8-inch per side as I understand. The earlier SN-95 version with the dogleg (vs. straight) steering arm is the preferred donor spindle FWIW.
