Results 1 to 3 of 3
Thread: Donor spindles to Factory Five upper/lower control arms
    Dec 2017
    Southern Ontario
    Will donor spindles attach to the Factory Five upper/lower control arms? Spindles are 99-04
    Thanks again,
    Higgy
    Short answer yes. With the required upper ball joint adapter. http://www.factoryfiveparts.com/1381...apter-bracket/. That spindle is also slightly wider than previous versions. About 3/8-inch per side as I understand. The earlier SN-95 version with the dogleg (vs. straight) steering arm is the preferred donor spindle FWIW.
    Dec 2017
    Southern Ontario
    Thanks Paul! When you say wider, do you mean the stance will be wider? I have already acquired the ball joint adapters.
    Edit...just acquired the 94-95 spindle with the dog leg!
