Thanks Thanks:  2
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 92
Thread: CDobbs MK4 base kit build by wallace18
    Rotonda West Florida
    Did you apply Lizard Skin to the bottom and top sides? IE, ceramic for insulation and the other for sound insulation?
    I'm interested in this approach rather than a Dynamat solution if it makes sense.
    Any feed back folks?
    wallace18's Avatar
    Trenton, Florida
    With Lizard skin you must first apply the sound deader coating, then the ceramic heat coating. I do this on the outside of the footboxes and trans tunnel area. I then install Eastwood X-mat on the entire interior cockpit inside. I have done this on multiple builds with great success as far as heat and noise.
    wallace18's Avatar
    Trenton, Florida
    Today I finished up fuel tank area hoses, wires and lines. I made a charcoal canister. I made all the brake lines and bled brakes. Found out I forgot Chris wants to install line lock. I will have to redo front brake lines tomorrow, . Installed rest of trunk aluminum.
    wallace18's Avatar
    Trenton, Florida
    I siliconed passenger foot-box and installed X-Mat inside as well. I installed inside drivers foot-box and top inside aluminum panels. I made up my own brake light switch bracket. Installed heater/defroster, wiring harness's, ECU computer and clutch cable. Chris came by after lunch and installed his ignition wires, nice job by the way. Hope to install engine/trans tomorrow.
    wallace18's Avatar
    Trenton, Florida
    While waiting on some part answers, I mocked up the dash so it can be removed with the body on. You never know when you may need to get at some wiring down the road. I use aluminum angle and tap it for 1/4-20 S/S button heads to mount dash later. Chris decided to postpone line lock till down the road after car is done. After lunch I installed engine/trans and started running wires and such.
    wallace18's Avatar
    Trenton, Florida
    Spent all day on wiring harness for engine and fuel lines. I covered fuel lines with 2 different heat sleeves. I may header wrap #3 and #4 pipes out of head to help with heat near fuel lines as well. I have 90% of EFI/Engine harness done. Throttle cable and clutch cable routed as well. I have P/S lines on rack, ran out of time to finish up to pump.
    wallace18's Avatar
    Trenton, Florida
    Not much to take photos of today. Finishing up wire harness for engine, installed coil and made up coil wire, installed O/P and W/T sensors and wiring. Hooked up P/S hoses and filled pump. Installed drive shaft and filled trans with fluid. Plumbed up P/B booster. Worked on getting all the pedals and cables just right and installed stops. Taking weekend off for good behavior, LOL.
    wallace18's Avatar
    Trenton, Florida
    Installed 95% of cooling system. Rubber mounted radiator. heater hoses all run. Installed J-pipes and O2 sensors. Finished up air intake and MAF sensor. Waiting on some stuff from Summit so I can start engine.
    wallace18's Avatar
    Trenton, Florida
    Scored a nice 5.0 intake bolt plate on E-Bay. Installed the Whitby frame brace around booster. Started wiring the FI relay/fuse panels.Installed heater valve and temp sensor in lower radiator hose. 5.0 intake does not support 3 water temp ports like aftermarket intakes do. Filled engine with 50/50 coolant mix. Hope to start it tomorrow sometime in the afternoon.
    wallace18's Avatar
    Trenton, Florida
    Milestone today, started engine! Seems to run great. Waiting on POL parts so I can go-cart. Good oil pressure and fans come on when they should. Got lucky I guess, LOL.
    Jan 2018
    Woo hoo!
    wallace18's Avatar
    Trenton, Florida
    As good as it has been going I guess I was due a bad day. It started out good as I swapped out the fan sensor and temp gauge sensors. I liked the temp sensor in the head vs in the lower radiator hose. I refilled engine with coolant and started working on interior wiring. I came back from lunch to see water dripping from the bell housing area. I looked at the drip and it was coming from the oil pan in the passenger rear area. Well I looked everywhere I could and could only see water dripping from the oil pan. So I drained the oil, no water. It wass still dripping under car by the oil pan. I pulled the pan to find it was the thermostat housing all the time. I ordered the parts to fix and called it a day. Hope tomorrow is better.
    wallace18's Avatar
    Trenton, Florida
    Still waiting on a thermostat housing. So I mocked up the center console, under dash panels and made spots for radio, speakers and heat vents. Speakers and vent will be hidden when you are seated in cafe and from above. I will cover dash with FFR supplied cover and rest with marine grade black vinyl.
    wallace18's Avatar
    Trenton, Florida
    Normally I do not work on Saturday but, this week has been weird. I reinstalled the oil pan and went to install the T-Stat. housing and low and behold the lower stud pulled out of the intake when I went to tighten the housing down. Most likely the reason for the leak in the first place. I ended up installing a heli-coil. I went and covered the dash so it felt like I got something done. Oh the joys of Kit car building, LOL.
    wallace18's Avatar
    Trenton, Florida
    I have been chasing a coolant leak around the Thermostat housing for several days. It turns out the lower intake is bad. Chris is going to get another. Today I worked on covering the under dash panels and finished wiring all the dash, radio and electronic antenna. Tunes are coming out of speakers, Yea! I have to recover the radio console. I am not happy with the first result.
    wallace18's Avatar
    Trenton, Florida
    Today I finished up radio console. I also started to replace lower intake. Hopefully this will fix coolant leak.
    wallace18's Avatar
    Trenton, Florida
    Yesterday I was able to finish up intake, no coolant leaks-Yea! I installed seats for holes to be drilled and installed slider on drivers seat. Marsha and I tried to bleed brakes but could not get any pressure out of rear circuit. I ordered another master cylinder and now have pressure but a soft pedal. May still have some air in it. At least now all 4 brakes grab. I removed seats and installed X-Mat. POL front shocks and trans bracket came Fed Ex so I finished up front suspension and trans mounts. I also drilled and mounted roll bars.
    wallace18's Avatar
    Trenton, Florida
    Running out of stuff to do. Waiting on upper steering shaft so I can go-cart. Also wheels and tires should be here by end of the week. Today I mocked up the rear lights, front lights, fuel filler and hood scoop. I do not like to use front T/S lights to hold body brace. So I mount the light 90 degrees from the holes that come from FFR and will countersink some screws for the brace when mounting the body. That way if you ever need to remove the light it won't mess with body position, JM2CW. Going to put the MK4 under cover till parts arrive. I may do a little work on my 35 stuff.
    Wallace18,
    I'm about three hours away. Found out my 35 is going on the truck this Friday (fingers crossed). I"d like to visit you if possible and maybe be of assistance for a few hours. Let me know if possible.
    wallace18's Avatar
    Trenton, Florida
    Quote Originally Posted by KenWilkinson View Post
    Wallace18,
    Sure thing. PM sent.
    wallace18's Avatar
    Trenton, Florida
    Made some panels to hide roll bars and seat belts in trunk area. Also Powder coated quick-jacks and painted trunk hinges. Chris came by to check out build. First time he heard it run in the flesh. He is a happy guy, LOL.
    wallace18's Avatar
    Trenton, Florida
    Still waiting on some parts. ***Just a note to those who are thinking of doing a base kit build. The base kit does not come with hood hinges and gas struts. It comes with hood pins and you will have to lift off the hood. Spend the extra money and get the hood hinge kit. I just ordered it for Chris. IMO the complete kit is a better way to go. I am glad to be doing this base kit build so I could see the differences myself. I am going to have some minor surgery next Wednesday and will be out of service for 2 weeks, so parts waiting is not so bad. LOL.
    wallace18's Avatar
    Trenton, Florida
    For the last week I have been going crazy not working on a car. Since I am allowed to lift 20lbs, I went and painted the hood hinges. I then installed the kit on Chris's hood. Hopefully on Wednesday I get the go ahead to start back on the cars without restriction.
    wallace18's Avatar
    Trenton, Florida
    Wednesday the doctor gave me the OK to get back to full work load. Yea! Thursday the steering shaft came and Chris dropped off the painted wheels with tires. Today I installed everything. Shimmed up the pillow block near the steering wheel for clearance on the frame. Then I did a front alignment. Then Go- carted it. Storm was in area so no video yet. I barely made it back to the shop before the storm hit. I had to modify the tie rod ends. As they were off the 1992 donor they would not allow for toe in with lock nuts installed. I removed lock nuts and drilled and tapped for set screws and lock nuts. Now everything is cool. Chris is coming over on Sunday to drive go cart and help me put body on.
    Tom-
    It's about time you got back to work! HA
    Very pleased to hear the doctor cleared you for everything, and I know it must feel good to be back in the garage!
    Chris has to be pretty stoked to be able to go-kart. I look forward to reading about how that goes.
    I look forward to your regular updates on your myriad projects!
    wallace18's Avatar
    Trenton, Florida
    Chris came by after church. He got to go-cart it. Nothing but smiles from him. We then dropped the body on the chassis. Here is some pics and a video.
    https://youtu.be/YTpdeBKtjdQ
  27. Thanks WIS89 thanked for this post
  28. #67
    Oct 2014
    Vermilion, OH
    Looks like Chris enjoyed the go-cart lol. Looking good Tom.
    CVOBill
  29. #68
    wallace18's Avatar
    Trenton, Florida
    Today I centered and bolted down the body. One thing I do a little bit differently is I countersink 2 S/S screws to mount the body to the front body braces instead of using the turn signals. I then drill 2 holes for the turn signal 90 degrees from the FFR holes. I also installed the hood. I still need to trim it for the 3/16" gap. Car is coming along very nice.
  30. #69
    wallace18's Avatar
    Trenton, Florida
    Got a lot done today. I gapped the hood, trunk and doors. Then mounted all of them. Installed the windshield, hood latches & door latches as well. Make sure you mount windshield 27" from rear door opening in case you ever want to install soft top.
  31. #70
    wallace18's Avatar
    Trenton, Florida
    Wired up all the tail lights and front lights. I use weather-site connectors from Summit. I also mocked up all the splash shield and radiator aluminum.
  32. #71
    wallace18's Avatar
    Trenton, Florida
    Finished up all I can do til I get side pipes back from ceramic coating. I clearance the roll bar holes, mocked up the rest of the aluminum, rear view mirror and located defrost vents. Chris cannot take car for bodywork/paint for 3 weeks. So on the 4-post the MK4 goes and the 35 on my 2-post.
  33. #72
    wallace18's Avatar
    Trenton, Florida
    Chris brought by the ceramic coated side pipes late yesterday. I mounted them today. I do the brackets a little bit different. I install thread inserts in frame for rubber mounts and clearance the brackets around the frame some. Boy they sound great! First set of FFR side pipes I have installed. Usually install quiet pipes. Now car will go to Chris on the 23rd for body work and paint.
  34. #73
    wallace18's Avatar
    Trenton, Florida
    Delivered the MK4 to Huegenics this morning. We also went down the street and had it weighed. 2160 lbs without driver. Chris will do bodywork and paint now.
  35. #74
    wallace18's Avatar
    Trenton, Florida
    Went to Huegenics today to help Chris remove body for paint. He modified the doors for more room as well as a neat deal around the side pipes. Should be getting paint over the next few weeks. I took chassis home for clean up and interior work when I get back from Vacation.
  36. #75
    wallace18's Avatar
    Trenton, Florida
    Got back from vacation and drove my 35 out and into my home garage. I pressure washed MK4 frame to get dust off from bodywork. I cleaned everything up and started to install carpet. Hope to have chassis ready for painted body by Saturday. Chris is holding me up, LOL. Guess I will light a fire under him, NOT!
  37. #76
    wallace18's Avatar
    Trenton, Florida
    I finished up interior and trunk area. Just a few more things to knock out and it will be ready for that gloss black body!
  38. #77
    Aug 2018
    With Lizard skin you must first apply the sound deader coating, then the ceramic heat coating. I do this on the outside of the footboys and trans tunnel area. I then install Eastwood X-mat on the entire interior cockpit inside. I have done this on multiple builds with great success as far a s heat and noise.
    I'm admittedly ignorant regarding these cars, but with the wind noise of an 'open cockpit' roadster having side pipes that blast just below your ears, I'm curious as to how effective or necessary a sound deadener of any type would be. The heat shield, I get.
  39. #78
    wallace18's Avatar
    Trenton, Florida
    It helps with the aluminum not vibrating and makes the interior more comfortable in my opinion. If you thud the floor without the sound deadener and then with, you will see a huge difference. When the car is not not noisy. IMO it is well worth doing.
  40. #79
    wallace18's Avatar
    Trenton, Florida
    Well I am done with everything I can do till body is done painted. All loaded up in trailer . Maybe by 2nd week of OCT???
  41. #80
    wallace18's Avatar
    Trenton, Florida
    Took the chassis to Huegenics to mount body, doors, hood and trunk. Mounted a few other stuff. Brought it home to work on my lift to finish it up. Possible hurricane Michael on the way also.
