The mod described below is a combination of the e-brake mods by edwardb and carlewms. I started out planning to do just the mod by edwardb, to relocate the e-brake cables over the 4" transverse tube using pulleys. That mod was straightforward. However, the Lokar clevis hit the bottom of the e-brake bracket when the brake was engaged and, although that probably didn't have any practical effect on the integrity of the mechanism, the engineer in me didn't like it. So, I looked at the ratchet handle extension that carlewms did (his photo below):
I didn't want to construct the entire handle so I opted to make handle extensions using soft steel bar (1/8" x 1/2") from McMaster-Carr. The goal was to move the clevis attachment pint another 1.5 in. from the ratchet pivot.
The side view (below) shows the pieces attached. Note also the modification to the Lokar clevis: this is the same modification done by edwardb to widen the attachment area.
The photo looking down shows the attachment from another angle as well as the spacers I put in using the steel tubing. Note the angle of the extension bars achieved using a spacer at the ratchet handle attachment pivot point. I also needed to purchase a longer shoulder screw because of the added width due to the extension bars and washers.
The view from the transmission tunnel shows the set up in place. Now the clevis assembly doesn't hit the bottom of the e-brake bracket. An additional advantage is that the angle of the cable relative to the pulley is slightly less than without the extensions somewhat mitigating the rotational force on the pulley bolt when the brake is set.
Here is a list of the parts used in the modification.
Lokar clevis: (Lok-S-8078)
Pulleys: McMaster-Carr (p/n: 3434T24)
A longer ‘shoulder screw’ for the pivot point: McMaster-Carr (p/n: 91259A622)
Steel tubing: 3/8” O.D., 1 ft. long; for spacer material (McMaster-Carr (p/n: 8910K393)
Steel stock: 1/8" Thick, 5/8" Wide, 1 ft. long; McMaster-Carr (p/n: 9922K15)
Various bolts, washers and nuts.
-Bruce
