Results 1 to 3 of 3
Thread: My Accusump install location.
    Thought I would share my mounting location for the largest 3qt Accusump with an electric solenoid.
    Senior Member beeman's Avatar
    Indiana
    Nice, I'm planning on installing the same unit with the electric solenoid. One thing I saw that I really like is an indicator light on the dash that's tied to the solenoid. Solenoid will open each time you start the car so you know it's functioning each time you take off. How did you tie into the engine? I'm thinking directly into the block.
    GTM #304 LPE 525hp LS3
    Dry sump was out of the question after installing A/C. I used and adapter that bolts in the port by the oil filter. It was recommended by Accusump. Would have to look up what it was again, but it was from another company.
