0
0
New Delivery #9279 - Steering Bracket Frame Question
I received my MKIV complete kit this week and am surprised that I already have what I am hoping is a dumb question.
As I was checking for the 3/8" clearance between the aluminum and the body, I noticed in the forward cockpit that the bracket that is welded to the frame where I believe the steering pillow block will be attached looks much different than what I have seen in pictures here in the forum and what is depicted in the manual.
I am attaching 2 pictures with the suspect part circled. Can anyone tell me if I have a problem? Thanks Glenn
You don't have any problem this is a change that was made and is for the better.!
Nothing wrong with the old style, just newer style and allow for the pillow block to be closer the steering wheel
Thanks for the quick reply. That helps give me some peace of mind at the beginning of my build!!
Glenn
- You may not post replies
- You may not edit your posts
Forum Rules
