Results 1 to 11 of 11
Thread: Fiberglass Body weight-MKV roadster
    Lake Mills, WI
    Guys,
    I am in the process of building my body buck-
    I am going to hang it off the ceiling-
    How much does the fiberglass body weight?
    Someone will likely be able to give you an exact number, but my estimate based on when me and my neighbor removed mine is under 150 pounds without the doors, hood and trunk. It may even be closer to 100 pounds. The buck weighs way more than the body.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Lake Mills, WI
    Thank you good info
    Just want to make sure I use strong enough pulleys
    M
    Aug 2012
    Grand Rapids, MI
    I weighed mine, 140-145# from what I recall. Body only, no attachable parts. The way they are manufactured I would guess that there could be a 10# variation.
    Jim
    Santa Clarita, CA.
    Hanging the body
    Like other have stated, the body is pretty light. Mine hung from my garage ceiling for 5 years.
    Only took two of us to hang it. I think the lowest point was a bit above 6'-8".
    O'Fallon, MO
    I hung my body to the ceiling directly, no body buck. Used large plastic hooks in the wheel wells, hung there for many years, zero difficulties, no distortions.
    Member cwrandolph's Avatar
    Sidney, OH
    Mine is a Mk 3 but I'm pretty confident that the body alone (no doors, trunk lid or hood) is under 100 lbs.
    Lake Mills, WI
    Thank you Fellas
    Just finished the body buck-
    I am going to suspend it with two canoe kits. each will hold 150lbs
    https://www.amazon.com/RAD-Sportz-Ka...CGFTHNDPRVWJZE
    Thanks again
    Jan 2018
    From the parts catalog, the shipping weight is 110lb for a body without doors, hood, trunk
    http://www.factoryfiveparts.com/1509...in-body-shell/
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by magicmarto View Post
    Thank you Fellas
    Thanks again
    Awesome tip. I just ordered a couple of those
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Lost Wages, Nevada
    They sell those "canoe" hook kits to hang mountain bikes too . . . have two in my garage now holding ours.
    But back to the original question . . . I suspended my MKII body from my garage ceiling for months at a time as I did different [body off] mods over the years. Never thought about the weight much as I set up four 150# pulleys with 200# nylon line to pull it to the ceiling. Two people to raise it easily. Body buck was altered to just be the parts needed to support the wheel wells. Worked quite well
    You'l be fine with what you are working toward . . .
    FWIW, the original specs for a MKII with hood, doors and trunk is 190#.
    Doc
