Brake pedal hitting costs tube
I have both master cylinders installed — Mark IV complete kit. Wildwood pedal assembly. The brake pedal when the pressure is off hits the the cross tube. I have tried threading the push rods in and out, but I’d doesn’t seem to make a difference. I do not see any other way to adjust. Thoughts?
That is how you adjust them. By threading the push rod in/out of the clevis attached to the pedal arm. There's a spring and retaining ring in the master cylinders that force them all the way out to a fixed location. In this position, the pedal must stop short of the frame cross piece. Otherwise the master cylinder will not work correctly. Sometimes it's necessary to trim a little off the end of the pushrod so that it goes in far enough. I believe that's mentioned in the instructions.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Thanks! I’m going to have to cut the push rods. Pedal still hits when fully threaded. I’ve seen some other comments where the issue solved after removing 1/2 in. From push rod.
