Hey guys--
I have a quaife LSD in my 5MT. Should I run 300 LS fluid? Or just regular fluid? I have LS in there now but the car hasn't been run under its own power since the diff install. Any insight?
Hey guys--
Frank - Build thread
Helical diffs such as your Quaife unit, or OBX units, do not require limited slip additives. Additives are necessary for clutch-type options such as the Cusco units that are dependent on the friction characteristics of the diff fluid (which in the Subaru case is also the trans fluid). So you should just run Subaru's recommended gear oil type and pick a brand you like.
Build Website: www.818coupe.com
Subscribe Link: https://feedburner.google.com/fb/a/m...&loc=en_US
