Results 1 to 6 of 6
Thread: Solid rear
    Solid rear
    REAR1.jpgREAR2.jpgREAR3.jpgREAR4.jpgI'm new to building the '33 - can any one send good pix what the two brackets mounted to the solid axle should look like. I hope my images you can tell if I did it correctly (bolts aren't tightened yet). Also they say to use the long bolt - I actually have two long sizes - one seems too short as the bolt doesn't go through the lock nut and the other is too big. I can simple get one that fits but was wondering maybe I just have the brackets in the wrong place. The manual's pix are no help. How tight to tighten the large bolt since it will deflect the bracket?
    Walter
    Not sure I understand the deflection part of your question - there are shocks or control arms in every gap that you are bolting. All come with washers/spacers - in some places I had to add some extra washers to make a tight fit. You won't want any deflection of steel parts. I can post closeup photos of finished 3-link setup if that helps?
    Here are mine
    I did get a few images, but still slightly puzzled, so if no problem posting your images should definitely help.
    Walter
    Hope these help. Mine is on floor, so not easy to get what you need. I'd choose bolts based on the load going on shoulder, not a thread where possible. If you zoom in you'll see I added washers on both ends, and padded with washers where spacers weren't quite enough.
    Senior Member TDSapp's Avatar
    Frisco, TX
    Here are some photos of my 4 Link. It might be easier to see since the rear end and frame are blue and the brackets are black and silver.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
