Coyote PCV hoses
I found a method to update the Coyote PCV hoses without breaking the bank and on a full set of AN fittings; especially the one that goes in the CHC for $140/pair! This seemed to work well so I thought I’d share.
I had extra AN10 hose laying around so I only needed to buy these Fragola E-Z clamps. After cutting the OEM tubing off the quick connects, I removed the O-ring. Next I slid the clamp onto the braided hose, then using the heat gun, warmed up the hose ID. It takes a little force but you can get the warm hose to fully engage with the plastic barbed connector. Tighten the clamp when in the desired position.
PCV clamp.jpgRH PCV side.jpgRH PCV front.jpgLH PCV make up air.jpgWile E Coyote PCV hoses.jpgPCV hose components.jpg
