Thread: MK4 Base Kit engine question.
Hybrid View
    wallace18's Avatar
    Trenton, Florida
    I will be building a Base kit MK4 using a 92 5.0 Mustang donor. I want to reuse the alt. and P/S pump, but not the A/C compressor. Do I have to get different brackets for the P/S pump? The PDF manual says to use non-A/C P/S brackets. Those are impossible to find in Florida. Everything here has A/C. Anyone have anything that they used to have the original P/S pump work from an A/C car? Thanks, TW
    Someone makes an A/C delete kit that just replaces the A/C compressor. Google it to find one.
    Chino Valley, Arizona
    Jeg's, Summit Racing and Late Model Restoration all sell one.
    Ford Racing A/C eliminator:
    https://lmr.com/item/M8511A50/85-93-...CABEgKYuvD_BwE
    It does away with the massive combined A/C and P/S bracket and moves the pump inward toward the block which allows for steering shaft clearance. I used it way, way back when (found the date on the photo was 2006!) on my own car along with a home made alternator mount and run the belt in a big "V" configuration.
    Eleven years, thousands of 6,000+ RPM floggings, no problems
    Good luck!
    wallace18's Avatar
    Trenton, Florida
    Thanks everyone! This forum is awesome!
    wallace18's Avatar
    Trenton, Florida
    Had the donor Mustang delivered last night. Turns out it already had A/C delete installed. Thanks again to all that answered my question. TW
    I think you can make that a lot less intrusive. looks like you could throw out that huge aluminum thing. Make up some spacers to use a longer version of the top bolt in the steel bracket and mount a pulley right onto it. I imagine Ford made it that way so it could replace the AC comp. and still use the same length belt but wow, that thing sticks out like a sore thumb.
    Great reference for 302 EFI belt routing options:
    https://lmr.com/products/fox-body-be...ting-length-50
