ReinCarNation
Results 1 to 40 of 49
Thread: Wilkinson 35 Hot Rod Pickup
    Rotonda West Florida
    Got my delivery date. 5/12!
    No fenders
    302/T5 trans
    powder coated
    heat and AC
    Will probably build similar to the SEMA version. Looking for wheels right now. Coker has the tires.
    Engine is in build now.
    Ken Wilkinson
    Congrats Ken!
    I upgraded your account for full access. Here are a few threads to help with pic hosting, and maintaining your thread title as you work the build:
    Embedding pics:
    http://thefactoryfiveforum.com/showt...tures-in-posts
    Maintaining thread titles:
    http://thefactoryfiveforum.com/showt...tle-Guidelines
    Loveland, CO
    Ken, welcome to the mayhem.
    Ralph
    Getting Real
    It's getting real folks. Got the axle from Mosler today. Truck is loading either this Friday 5/19 or Monday.
    Axle picture. Can't figure out how to embed, will try below if doesn't work use this URL: https://photos.app.goo.gl/a21CqnYfH8cBGXk32
    HTML Code:
    <a href='https://photos.google.com/share/AF1QipN6pcdSqN6IxWwyBhsEc8Y5Ge8wmNAc46NadhhRME_-3EDvO0yY5cxAGYS7o0O-SQ?key=VWZWNHAzWkVkT2xuUWU5RkVHVVRzOEsxcGd4bjR3&source=ctrlq.org'><img src='https://lh3.googleusercontent.com/kmcNfjcAqqoUa-owtbf0C_Gq0lrNhpBV81WoRZwNltFWDOMb62dvm0oplxgt9VkoGWQq9IzKnieH3Bha4TRhOw-xPRav_b959l6yK8nnDlv7huerHO6e__23DDMEWB5zVVYX6d7i=w2400' /></a>
    mburger's Avatar
    Punta Gorda FL
    Good news Ken. Won’t be long now.
    Mark
    Mk1, Frame #1929 stock 1990 EFI 302, T5, 8.8 axle 3:55, PS, Heidts, heat, fresh air vents, Russ Thompson Turn Signal mod, windshield wings FFR front lower control arms, Speedhut gauges, Alex's glovebox, cup holders. charging ports. 70K on the motor and 7,200k on the car.
    Hi Ken, I added [img] tags around the rather long url below to embed the pic:
    Code:
    https://lh3.googleusercontent.com/TXvlMdW0NqGhCTicWdYuSdij-J-MNn-xQriN5BURCFaDm-9XI8yHlGk-cyWiQGqYdX61aRMy-b2Pjz2nS28tNpff0uaFFVND12H8r7BgYH9OTNWJAQPfHyQv7beAD1_EFbptzcVS96aWM5udTzFZACai8M_ryqh2MN9HF7cEC9LLx6eRyiFMQVRb_baU26HYA9FamFKteDtayU93UIMedJRVhXbkoOpkX5vLDqjGwNKSHQKNC5GDqkqu0lB5im9855KenjKXtPOlPoxVgpBBvPwEyY5KtlyPmtE7DZRR9YKW3Ex9u5DrG7vMdQyMm8jk3yWOWMl8l08WiMLMERfXQ_q_X4Ya6DMAyN9RYusjWXZmwQn-iX2b6jn6tUiBIKUyC2dhedzG3asU1ipLlSEtWryXjqrvahgP8ludkA9rKAK0EhMHV4PwofL2lFwfg3krvX6a5vyPxDyY8fBiU4q0632_uRIp5r21lt5T0XXDMIBB-r-Qn9VdDySXtCmjqMCGvwxhFNYrvJsZIYX0W6A2znJRdF0fDgcrVeUs4DTrZ6fXGY8zKD5FMU1y3v0FU6FVkkVosiaSMaCWC7U4QIvzhcIdS9yTDQ4jO31me8X75JYGJv_E6R9Qpl8j9YwKnSNa3uxsP93wfbSio6U85k0Ro5JLDq9sz0g=w1184-h888-no
    Hope That Helps! (HTH)
    AH ha! thank you!
    wallace18's Avatar
    Alachua, Florida
    That looks like the right one for sure. You can see the rear axle I have tomorrow when you visit.
    Jan 2018
    Twin Cities, MN
    Quote Originally Posted by KenWilkinson View Post
    AH ha! thank you!
    Hey there - What came in your manilla envelope? Mine was sort of shredded from UPS and only had a brass breather valve in it. Did you get anything else from Moser? I want to make sure I'm not missing parts.
    Yes, brass fitting, Stickers (yeah!) and instructions. It is damp so I am letting it dry indoors. Do you want me to scan and send the paper stuff?
    Senior Member Marv's Avatar
    Nov 2012
    Tucson, AZ
    Looking at the picture of the differential it has a late model (2015 I believe ) flange on it. These flanges take a shaft with a rubber coupler at the end. My differential is the same, my question for anyone that knows is do we change it out for the older style flange? I assume that the driveshaft included in the kit is designed for the flat 8 bolt flange not the newer six bolt.
    2008 FFR 5851 Copperhead Orange with ghost stripes by “the Bat”, Ford Racing 345 HP, Tremec 5 Speed
    2012 FFR 33 HR, won Best Use of Chrome Huntington Beach 2014; 345 HP AOD
    Deep Impact Blue
    2018 FFR 35 Pick Up, building, getting there.
    Quote Originally Posted by Marv View Post
    Another view of the axle with flange - sigh, can't get the image again. Use this link. https://photos.app.goo.gl/Tro5RmGrbTliI3ro1
    Someone tell me what is wrong below please.
    [img<a href='https://photos.google.com/share/AF1QipOT9TaO7CMnFGxQaJtzyz3yZFrR-mzMAexPqzJAxo1O4LjqBw98Tx9bi3CB3mlNlw?key=LXhPUE5l aGk1RlVma0JaaWJqTFFMd0NYWUg0aklB&source=ctrlq.org' ><img src='https://lh3.googleusercontent.com/Fc0eSXWXAgchgGYtCPVskFC8uMiMjTChTuMJ0wDHVtO3W3CJAi ZKxh24qI8uMlTf2zJHjfVXXokxX5yFyCUMbPttaTt4o1Rce-Ud06LzlxlvLtQSmuyeLLWeGZpwvmMximUM8I-7=w2400' /></a>/img]
    Jan 2018
    Twin Cities, MN
    I’m going to call Moser and have them send it to me. Thanks for the offer though.
    Bourne-Cape Cod, MA
    You will use an adapter like on the IRS, The flange stays intact on the diff, and the driveshaft is the similar as used on older mustangs, It is a four bolt flange on the driveshaft. It may be the same driveshaft flange as older Mustangs, I have not compared the two side by side. But it looks the same.
    FFinisher/AKA RE63
    Port Charlotte, FL
    Congrats Ken,
    Looking forward to meeting you and watching your progress.
    Thx,
    Henry
    Loveland, CO
    FFinisher, so did this "adapter" come with your kit? What does it look like? I am familiar with the procedure as on my old 3.1 roadster (solid axle), but this discussion is foreign to me. From your comment, I gather there is some type of adapter that connects the old style driveshaft (provided with kit) and the newer style rear axle. Is that correct?
    Ralph
    Bourne-Cape Cod, MA
    It is a round steel adapter that bolts to the flange on the axle, then has a bolt pattern that matches the driveshaft. Yes the adapter and the bolts come in the kit.
    FFinisher/AKA RE63
    Senior Member TDSapp's Avatar
    Frisco, TX
    Ken,
    You have to close the [IMG tag with a ] and then start the /img] tag with a [. You also only need the URL for the image and not the <img tags or the closing />.
    So the URL will look like this....
    https://lh3.googleusercontent.com/Fc...imUM8I-7=w2400 (The entire URL will be there... the Forum shortens the long URL with the ...s and make it look better.)
    Just put the [ IMG ] and [ /IMG] tags around it. (No spaces in the tags... I did that so they will show up.) You might have to "Go Advanced" and then hit "Preview Post" a few times until you get it right. But after that first time of getting it you will never have a problem again. It also helps that most forums work the same way.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Contacted by Jolene at Stewart! I'm on the truck -BUT- last off. I'll take that. ALLEN the driver says here by 6/18. A Monday. A great way to start the week!
    mburger's Avatar
    Punta Gorda FL
    Very cool Ken!
    Mark
    Arrived Saturday at 6pm. Two days early! Missing 6 or so boxes, that the driver has checked off. Hmmm...
    Will start inventory Monday June 18th. Anyone in the area is welcome to drop by.
    In case you were wondering... Missing 5 boxes that were marked on the truck. Missing key components as backordered.
    Can't start the front suspension missing the spindles and brakes.
    Can't start the shocks. Missing threaded shock body part
    Can't start rear suspension, missing those parts.
    Heavy sigh. No update on backorder or missing boxes yet from FFR
    wallace18's Avatar
    Alachua, Florida
    Ken I can tell you from experience this is not out of the ordinary for a new kit from FFR. One of the things that go with these kits is back ordered items. FFR wishes they could send everything the first time. It eats into their profit margin having to ship all these POL parts. They are at the mercy of their suppliers. I understand how irritating it can be, but patience is one of the keys to building a kit car. Paint and do what you can by skipping around. Pre-drilling aluminum is a good way to get stuff done ahead of time. TW
    expensive wind chimes
    Kind of expensive wind chimes
    All parts in raw steel and suspension that I have are painted. Suspension in two coats. I used Eastwood rust inhibitor first then Eastwood 2K Rat Rod Black Satin. Matches the black satin of the chassis exactly. Looks like they were powder coated! Awesome.
    https://photos.app.goo.gl/2Pcm5sH28VkpXzgX8
    wallace18's Avatar
    Alachua, Florida
    Looks good Ken!
    mburger's Avatar
    Punta Gorda FL
    Looks great! Some early morning on the weekend I’d like to take my Mk1 over to check out your progress. Weather is always an issue as you know this time of year.
    Mark
    today would have worked! Next weekend, I'll be in Columbus Oh for the Good Guys show there. Drop by early evening too if you wish. I think you have my cell number. Not much to show yet, missing key parts for lots of the kit. But you can look and see how it starts out....
    Loveland, CO
    Ken, I can identify with your post of missing boxes and items. It seems to match the same things missing in my shipment. When you have a critical part missing that is needed to start each major area of assembly, I guess you can always sand fiberglass.
    Hope some of your items have appeared.
    Ralph
    minor update
    Still waiting on Key parts.
    I got parts for rear brakes so that is completed and the new diff cover installed. I had to grind the inside of the cast diff cover (aluminum) to fit over the internal bosses. No biggie, but not expected.
    https://photos.app.goo.gl/1YrKRAMWe8uREtWJ7
    Note the front driver side shock. It is not plated correctly. I have a call in to FFR to find out what to do about it.
    wallace18's Avatar
    Alachua, Florida
    Have them replace it. Send them a photo.
    latest updates
    Got parts in the last two weeks. Finished the front suspension, Steering rack installed, Rear brakes, and Rear suspension completed. Yesterday finished the peddle box. Ordered Tires and rims from Coker.
    Engine done except for accessory drives. Got my T5, Bell housing, hydraulic clutch.
    Thinking i might work on the gas tank tomorrow just to get a big box out of the way.
    Once tires are on, I'm boost the truck into the air and do the emergency brake and hydraulic brake lines.
    Mar 2018
    Yucaipa, CA
    Have a question on rear brake. Have a 33' on way and had hoped to get it this week. Now Fri no call, no car. Maybe next week. Question,,, I have a 96' 8.8 rear end and have gone over it and all looks good. Cleaned up and painted with new calipers etc... But now I am hearing the calipers need to be on FRONT side of axle, not REAR where they are now. For parking brake install ????? I notice Your calipers on on front side, may be this is true???? I can change over, saw video on this, but prefer to leave them as is..... Oh what to do..... Thx
    Jan 2018
    Twin Cities, MN
    Quote Originally Posted by OnlyAndy View Post
    Take a peek at this thread for all things rear-end on the truck.
    https://thefactoryfiveforum.com/show...S197-(not-Fox)
    Mar 2017
    It only took 3 and a half months to get missing parts?
    Quote Originally Posted by Mick_d View Post
    Yup.
    herb fraser's Avatar
    Yup.
    you guys are lucky, I am still waiting on parts ! (:
    ordered in December 2017
    ready to ship on May 21st
    ship date nearly a week later
    ACTUAL ship and received June 16th
    Dwell waiting for parts until two weeks ago.
    Nov 2012
    Tucson, AZ
    Wonder if Hot Rod Magazine is waiting on parts for their build?
    Deep Impact Blue
    Now that's funny !,
    Big day for the 35 Pickup today eh?
    Tires arrived today. Missing front spinners
    As cast aluminum, Rocket Racing wheels.
    Tires are Coker
    600R16 EXCELSIOR STAHL SPORT RADIAL
    750R16 EXCELSIOR STAHL SPORT RADIAL
    front to back respectively
