Likes Likes:  2
Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
Thread: Wilkinson 35 Hot Rod Pickup
    Rotonda West Florida
    Oh, the wheels are as cast Igniter
    Mar 2017
    Norway / Merritt Island FL
    Nice looking wheels! I guess you can make black lins across Florida with anything more than 50 hp.
    50 HP? boy you are mean! ;-)
    I built a four post lift out of 2x4s
    Plenty of room to work underneath.
    herb fraser's Avatar
    Great idea !
    looks solid !
    Herb
    Got the idea from one of Tom Wallace's friends.
    Ken,
    Looking good! I'm very jealous! Keep up the good work!
    I lucked out. Getting the engine ready for the transmission. Dial indicated the flywheel, dead nuts on. Dial indicated the bellhousing, almost dead nuts, I don't need to use offset Dowel Pins!
    I hope this luck continues :-)
    Don't you love when it works out that way, LOL.
    painting some parts. Air cleaner is a sample of the final color for the body. Top of cab will be Wimbledon White (a 1964 Ford color) and below the beltline Ecurie Ecosse Blue (this is a Standox copy for Lotus called Lotus Racing Blue). Found a local jobber that supplies Standox paint so I don't have to travel to the UK!
    The Firewall is Wimbledon White and Kia Titanium Gray. It's a warm gray to complement the warm white.
  11. Likes shmelty liked this post
  12. #51
    All that looks great Ken!
  13. #52
    Love this old school style
  14. #53
    Aug 2018
    Hampshire, IL
    Looks great !!!
    I have the same caddy air cleaner I drilled some 2.5 “ holes in the front of it and plan to paint to match my truck with some air brush art work on it. F733282F-47A2-4FD5-8863-F28E48C2A174.jpg
  15. #54
    Senior Member Marv's Avatar
    Nov 2012
    Tucson, AZ
    Looking great Ken
    2008 FFR 5851 Copperhead Orange with ghost stripes by “the Bat”, Ford Racing 345 HP, Tremec 5 Speed
    2012 FFR 33 HR, won Best Use of Chrome Huntington Beach 2014; 345 HP AOD
    Deep Impact Blue
    2018 FFR 35 Pick Up, building, getting there.
  16. #55
    Finished Firewall painting. 2nd attempt got it right this time. Steering column, wheel and power steering (electric) all installed.
    I need to make a bracket for the PS controller. Trip to Home Depot will do it.
    Started electric today. Looks messy but everything is labeled.
    Ready to install the engine any day now.
  17. #56
    Looking good, you are getting closer every day now!
  18. #57
    Aug 2018
    Hampshire, IL
    Making progress
    Your firewall looks sweet
    Great job
  19. #58
    Port Charlotte, FL
    If you need help with the engine Ken, gimme a call!
    Henry
  20. #59
    PM sent.
    FFR 35 p/u # 0014
    I used to think I needed a Rolex watch, now I’d be happier with a Swedish K!
  21. #60
    Engine/Transmission installed!
    I needed help from my neighbors. But the engine is in!
    Thanks to Henry Renard (65 Cobra dude), Robert Vendette, and Dave Erickson! It made the job easier to have many hands.
    Going...
    Going...
    Going...
    in!
    Henry is musing something
    Power Steering and Oil Filter were in the way. I'll get a shorty filter, but the Oil Pan will need a strategic dent made into it.
    FFR 35 p/u # 0014
  22. #61
    Aug 2018
    Hampshire, IL
    Looking good. Great progress ken. I used a Moroso double sump pan and fit perfect with the electric steer unit.
  23. #62
    Ken you may just have to reclock the P/S. Way to go!
  24. #63
    Loveland, CO
    I had to search for a shorter oil filter. Finally settled on NAPA 1335.
    Also had to grind a little off the motor mount for PS to fit.
    Ralph
  25. #64
    The new manual says Purolator L17019.
    Of course, I'd built the engine first, before the manual arrived. Will try to clock the PS tomorrow before I resort to strategic denting.
    FFR 35 p/u # 0014
  26. #65
    so, had trouble with grill (long story) replaced with 32 Deluxe Grill. Top hose, ok. Bottom wow, what a pain. Reached out to others for assistance, rolled my own solution. Here is the pictures, in case someone wants to duplicate. Unseen or hard to see is a short 6 inch steel tubing and a rubber adapter (1.5 to 1.750 inch).
    Still not crazy about it. Worried about rubbing the hose between the springs. We'll see..
    part no 1.jpg . Used and cut back to fit to bottom of Radiator (1.5 inches here)
    part no 2.jpg . Top at water pump, also cut back.
    bottom 90.jpg .
    FFR 35 p/u # 0014
  27. Thanks FLFrank35 thanked for this post
