Results 1 to 5 of 5
Thread: Crash- Header tank question
Threaded View
    Senior Member beeman's Avatar
    Indiana
    I'm ready to order your header tank, plan is to ditch the front C5 surge tank and install bleed points the radiators. I've been through a lot of old threads and appreciate the effort you put into making our engines survive!
    I do have a question about something you talked about back in 2010... I believe you said you had to add a 2nd steam vent line because your engine is not level? Can you expand on that? Is that a typical issue (Porsche tranny)? Is there an existing port or would I need to drill and tap?
    Does your tank have all the fittings needed or will I potentially need to add any? C5 hose sizes, right?
    You talk about continuous flow through the tank, does that occur as configured? I'll be running a constantly flowing heater core (Honda unit) but I also may order your Heater Bypass Valve if that would divert warmth from the cockpit in the summer - it would, right?
    Thanks!
    One more question- does your Heater Bypass Valve draw continuous current in the open or closed position? Also, does it use engine vacuum or create its own vacuum?
    GTM #304 LPE 525hp LS3
