Thread: Upper Link Bracket
    Upper Link Bracket
    I'm assuming I can skip all the instructions (and don't see parts) regarding the axle clamp brackets/upper link bracket (3-Link). I purchased the rear from FFR and the part in question is already (welded) attached? Sorry for possible a dumb and obvious question - I'm sure more will follow.
    Also I see the rear requires 1.875 qt of 90 weight - should be OK to add 2 quarts? Also the manual talks about adding a "Friction Modifier" -no clue what that is or does AutoZone. ???
    Thanks!!
    Walter
    Livermore, CA
    Someone else will probably chime in on the friction modifier who knows more but Moser will likely have a recommendation, I believe it can depend on which differential you're running.
    Regarding the 3-link bracket, yes, you can ignore the instructions for installing it, that's for the clamp-on style used for the non-welded units.
    Senior Member JOP33's Avatar
    Haslet, Texas
    Quote Originally Posted by racephotoman View Post
    Thanks!!
    Walter
    I just picked some up from the local Ford Dealership...couple bucks.
    Not trying to confuse the issue (you've been given the correct answer already), but there is still some justification to add the third party banana bracket brace from http://vpmcobras.com/ IMO. Many of us have, and we've seen bent banana brackets.
    Apr 2014
    Memphis, TN
    I got the friction modifier from amazon, $9.
    https://www.amazon.com/gp/product/B0...&tag=pda0ea-20
    Ryan
    33 Hot Rod
