I'm assuming I can skip all the instructions (and don't see parts) regarding the axle clamp brackets/upper link bracket (3-Link). I purchased the rear from FFR and the part in question is already (welded) attached? Sorry for possible a dumb and obvious question - I'm sure more will follow.
Also I see the rear requires 1.875 qt of 90 weight - should be OK to add 2 quarts? Also the manual talks about adding a "Friction Modifier" -no clue what that is or does AutoZone. ???
Thanks!!
Walter
