I'm looking for the best place to attach the fuel filter to the chassis. There is a cross brace on the tube where the manual recommends so it seems I need to place the filter before or after the cross brace. However, the supplied tubing with pre-fit fittings is either too long or too short. Placing it after the cross brace is over the IRS in the wheel well area so I'm leaning toward putting it before the cross brace, closer to the tank. It seems i'll need to cut the tubing shorter and reattach a fitting. What are your thoughts?
I have external fuel pump that came with my Fast ez-EFI and it suggests putting the pump low so it gets a gravity feed. Where would you suggest attaching the external pump?
Thanks, Mark
