Results 1 to 6 of 6
Thread: Any engine restrictions?
    Rotonda West Florida
    This might be best answered by someone that has done a 33 HR. I'm building a DSS 306 ford (302) block right now. Would like to have an electric water pump, but with AC and Alternator getting a
    decent pulley system seems to be a challenge. Are there any oil pan or other restrictions that I should be aware of in planning the engine build? Thinking of FiTech or Holly Sniper for fuel intake.
    thanks guys. my delivery date is 5/12 and I'm about to go crazy waiting.
    Ken-
    I don't have an answer for your questions -- sorry about that... However, I had to comment on your avatar!
    Awesome seeing Steve here on the forum. Not enough o's in cool to describe him!!
    Senior Member brewha's Avatar
    Somers, Ct
    Cvfracing has setups for a 302 with an electric fuel pump. I’m building a roadster so I can’t help with the oilpan although my guess is a shallow 7 inch pan would be necessary. I’m running a Fitech on my 331 stroked motor and love the turn key startups. Snipers had a wait list when i was looking. I could have gone either way on the fuel injection. Fitech systems I have seen on sale for a good price recently but don’t remember where.
    yep, discovered CVfracing yesterday. I ALSO learned that electric WATER pumps don't have heater hookups. So I'm back to a short shaft combo water pump and timing chain cover. Ie, this one: https://performanceparts.ford.com/part/M-8501-A50
    I think this works on the CVFracing kit, but will call tomorrow to confirm. Interesting about FITEch, it is between them and Holly Sniper. What distributor did you go for? I've seen the 400HP kit for 795 recently.
    Hey wis89
    What is this steve fellow you speak of? The Avatar is my picture <grin>
    Somers, Ct
    My Fitech is the 600. Setup was simple and with only minor tweaks to the settings. I have a MSD distributor and a MSD coil. I have a neutral safety switch on the transmission so when I’m working on the engine, I can just reach in and turn the key.
    The hand controller is great when breaking in the motor and getting and logging info.....dumping that data into a computer produces some nice graphs to show what’s going on. Just don’t leave it plugged in why not using, it will drain the battery.
