yep, discovered CVfracing yesterday. I ALSO learned that electric WATER pumps don't have heater hookups. So I'm back to a short shaft combo water pump and timing chain cover. Ie, this one: https://performanceparts.ford.com/part/M-8501-A50
I think this works on the CVFracing kit, but will call tomorrow to confirm. Interesting about FITEch, it is between them and Holly Sniper. What distributor did you go for? I've seen the 400HP kit for 795 recently.
