Results 1 to 4 of 4
Thread: T5 noise
Hybrid View
    mburger's Avatar
    Punta Gorda FL
    T5 noise
    When my car is in fourth or fifth gear I can hear a “whiring” noise that I believe is coming from the transmission. In first, second and third gears all I hear is exhaust from the factory five pipes. It’s not a whine but a lower pitched noise. 30 years ago I had a car with an M22 transmission and gear and Sychro whine was a welcome sound as it was normal. I have no experience until last May driving with a T5 transmission. I am just wondering if I’m hearing normal transmission noise or if it’s the sound of a problem. To put this in perspective, we are talking about doing 65 on the highway and I can hear this low pitched whine/whir. The T5 is out of the donor car a 1990 Mustang LX with 69,000 miles on it.
    Mark
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Have you checked your fluid to see that its full?
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    mburger's Avatar
    Punta Gorda FL
    Walt, I haven't checked the fluid level, but there are no drips under the car, so I wasn't suspecting low fluid level. However, it's a great suggestion and when my car is in the shop next week I'll ask to check the fluid level. I'm getting new tires, new FFR front lower control arms/alignment and while the left rear wheel is off, check the build/frame number.
    Mark
    Dec 2013
    Navasota, Texas
    Mark the reason i suggested it , im getting mine ready for San Marcos and was underneath changing the oil and had oil from tranny back, i found out the speed sensor i had in there was for cable, which im not using and it was leaking allover the underneath so i changed to one that is sealed.
    Walt
