Thanks Thanks:  2
Likes Likes:  10
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 207
Thread: Marvís 35 Truck
  1. #121
    Senior Member Marv's Avatar
    Nov 2012
    Tucson, AZ
    Very nice! Are you working in Australia ? LOL.
    I found a photo editor! LOL
    2008 FFR 5851 Copperhead Orange with ghost stripes by ďthe BatĒ, Ford Racing 345 HP, Tremec 5 Speed
    2012 FFR 33 HR, won Best Use of Chrome Huntington Beach 2014; 345 HP AOD
    Deep Impact Blue
    2018 FFR 35 Pick Up, building, getting there.
  2. #122
    Nov 2012
    Tucson, AZ
    Seats fits very tight at the front at the trans tunnel have to move tunnel in some. Mounted hood hold downs and regulators are in. Next the glass goes in. Wednesday is the DMV for plates and registration.
    Deep Impact Blue
  3. #123
    Nov 2018
    Scurry Texas
    What do you think of the seat height? All the pictures i have seen with someone sitting inthem they looked to be trying to see over the dash? Have not seen in person yet.
  4. #124
    Nov 2012
    Tucson, AZ
    Seat height is a little low plus too far forward, going to do some experimenting
    Deep Impact Blue
  5. #125
    Alachua, Florida
    Quote Originally Posted by Marv View Post
    I too wish the seat was farther back, however it is already up against the roll bar bracket. I don't think you can get it back farther without modifying the seat back. Best of luck.
  6. #126
    Nov 2012
    Tucson, AZ
    Agreed don’t think we can do much with the FFR seat. Can’t even put the E brake handle in the location called for. I wonder what happened with the original design bench seat they have in the brown truck. I now know why when I asked to sit in the brown truck at Barrett Jackson they said they’re not letting anyone sit in it.
    Deep Impact Blue
  7. #127
    Jan 2018
    Twin Cities, MN
    So I made a modification over the weekend that helped install and let me keep the old e-brake design. I cut the seat frame in the front-most trans tunnel side. I cut flush with the main Frame and right in front of the welded nut for the trans tunnel cover. Makes install way easier and my e-brake fits. I ran this by Tony via e-mail and he didn't have any issues with it...
    Ill get a picture of the cuts in the next few days.
  8. #128
    Jan 2018
    Twin Cities, MN
    Also, I have a set of big/tall buckets I bought to make go-karting safer. Let me know if you're interested in those instead of the bench. They're extra for me now. I'm 5'9" so I have fewer sizing issues with the seat.
  9. #129
    Bourne-Cape Cod, MA
    Agreed donít think we can do much with the FFR seat. Canít even put the E brake handle in the location called for. I wonder what happened with the original design bench seat they have in the brown truck. I now know why when I asked to sit in the brown truck at Barrett Jackson they said theyíre not letting anyone sit in it.
    Marv, do you have the newest style E-brake? It is shorter at the rear and has a leg that goes down to the lower portion of the frame. This "should" allow for the e-brake to mounted where FFR has it designed.
    FFinisher/AKA RE63
  10. #130
    Nov 2012
    Tucson, AZ
    No I must not have the newest one. I check with tony. Thanks
    Deep Impact Blue
  11. #131
    Nov 2012
    Tucson, AZ
    Just an FYI plates and title acquired today for a 1935 Ford special construction. Now I can put a few miles on her. Did get nailed for $1140. Sales tax though. At least I got the copper historic vehicle plates. Hey you can take it with you. LOL
    Deep Impact Blue
  12. #132
    Alachua, Florida
    Congrats!
  13. #133
    Oct 2018
    ada minnesota
    I got my truck coming next week if all goes well am planning on reupholstry on bench seat and jack ing it up , tired of pillows under butt !! what seems to work for shifter? wanted a 16 in and ordered and it gonna be 10 in tall , going with 302 and AOD anyone got a Minnesota inspection and appraisal ????? think this will take some modifications to make me happy but I am excited and have the shop cleaned out
  14. #134
    Jan 2018
    Twin Cities, MN
    This cut job also meant I didn't have to modify the E-brake
    https://thefactoryfiveforum.com/atta...7&d=1545326347
    Quote Originally Posted by Stillwater35 View Post
  15. #135
    Nov 2012
    Tucson, AZ
    Good idea
    Deep Impact Blue
  16. #136
    Jan 2018
    Twin Cities, MN
    Here's how much the frame hit my e-brake, and here's how it looks with the cushion installed. I'm fine with it as it stands.
  17. #137
    Nov 2012
    Tucson, AZ
    Set my seat on 2x4ís to raise it some, cut these pieces out and spread the front open about an inch to get it to fit. Seems to me the roll bar gussets should be smaller and mounted higher in the future to allow the seat to be moved higher. Just my 2 cents.
    Deep Impact Blue
  18. #138
    Nov 2012
    Tucson, AZ
    Fitting door glass today, I found I have the wrong inner felts for the doors. Think they are for the HR make sure you have the correct length they go all around the inside opening.
    Deep Impact Blue
  19. #139
    Alachua, Florida
    Marv you have to use 2 pieces. You should have got 4 felt ones for the inside and 2 rubber ones for the outside.
  20. #140
    Nov 2012
    Tucson, AZ
    Tom, Received only two, I would hope FFR would cut them longer to eliminate needing two. We’ll see. I will report what they send me.
    Deep Impact Blue
  21. #141
    Loveland, CO
    I am with Marv. I have two pieces of the inner felt rubber, about 55” long each. Which appears to be the length you have. I have two Long rolls of the outer cat head (assembly manual term) rubber.
    However, the asssembly manual seems to imply on pages 336-337 to use the felt only around the top of the frame and fill in across the bottom with the cat head. Interesting.
    Wallace, did you get 4 pieces and run it all the way around?
    Ralph
  22. #142
    herb fraser's Avatar
    I removed the roll bar bracket and picked up 2 inches
  23. #143
    Wish my seat would come, got bored and modified the side covers
    love the side covers, nice upgrade
  24. #144
    Alachua, Florida
    Quote Originally Posted by rponfick View Post
    Ralph
    Yes ,4-felt
  25. #145
    Loveland, CO
    On window weatherstrip questions, where are the other 4 felted pieces supposed to go (#26037), 34.25" long. They look like window runner channels of some type, but in looking through assembly manual, they are nowhere to be found. Is it just common knowledge where/how they are to be installed?
    Also, I have a "U" shaped felted channel about 33" long, that I think is part 33529, called unbeaded window channel that must go somewhere?
    The journey continues.
    Thanks, Ralph
  26. #146
    Alachua, Florida
    Thanks, Ralph
    page 427 of BETA manual. shows your question.
  27. #147
    Loveland, CO
    I have looked near these pages in both assembly manuals and don't see the parts I was trying to find a home for. I understand what fits around the inner and outer window opening, but the parts I mentioned appear to be channels of some sort.
    Bear with me as I am old and dense, but I still don't see where these parts fit, and how to attach them.
    Thanks, Ralph
  28. #148
    Nov 2012
    Tucson, AZ
    Just an FYI update on glass install I found it easier to leave the inner felt off to align the glass with the outer seal and window track channel. Then I dropped the glass and installed the inner felt. ( the one that is not correct)
    Deep Impact Blue
  29. #149
    Nov 2012
    Tucson, AZ
    Found what I think is a good place for the window switches. Plenty of room to operate.
    Deep Impact Blue
  30. #150
    Nov 2012
    Tucson, AZ
    Thanks, Ralph
    Ralph, those pieces are for the 33HR not the truck. You do not need them. I’m not sure if the aluminum channel and felt u channel will fit in the front of the truck door. I don’t believe it will but will check later today and either remove this line or edit it. Maybe Tom will say if he was able to put that vertical channel in the door, I don’t believe it is needed but will check. I received those also. Look on page 551 in the printed 33 HR manual you get a better idea of all those pieces.
    Deep Impact Blue
  31. #151
    Alachua, Florida
    As Marv said that is for the 33 not the P/U. No need for it. The window tracks fine in the 2 seals that go around the door opening.
  32. #152
    Loveland, CO
    Great, thanks. I think FFR was just trying to confuse me. Which is easy to do.
    How do you guys like my seat solution? I am rather proud of it.
    Ralph
  33. #153
    Nov 2012
    Tucson, AZ
    Ralph
    Looks like it worked out great Ralph
    Deep Impact Blue
  34. #154
    Huntsville, Al
    so I had planned on this spot for my truck as well... then it occurs to me...I am a big symmetry guy.. are you planning to do the same for the pass side? If so.. there will obviously be no way to roll down the pass window from the driver's side.. or worse... roll it up... without stopping the truck , getting out opening the door and then operating the window.
    I ended up getting a 3rd switch... put 2 on the driver's door and one on the pass door... like OEM...
    the other option if you want to "hide" them and don't want to have 3 switches is you mount them to the bottom of the dash in the middle under the gauges...
    just my .02 anyway.
  35. #155
    Nov 2012
    Tucson, AZ
    Cool good plan, I can reach both switches even the one on the passenger side without any problems. I have plenty of clearance between the door and dash sides.
    Deep Impact Blue
  36. #156
    Loveland, CO
    Marv, I am working on my hood fitting and have followed the two ways to mount the hinge brackets to the radiator support. I see in your post #98 you have the brackets mounted inboard. Did you leave them that way? I have mine outboard and can not get the brackets to clear the cowl and align to the hood mount pad.
    Just looking for comments by those that have been there.
    Ralph
  37. #157
    Nov 2012
    Tucson, AZ
    Yes I have the hinges (black pieces) right next to the radiator on each side with the top of the mounts tilted in slightly, took a while to get everything lined up.
    Deep Impact Blue
  38. #158
    Loveland, CO
    Thanks, I will try them the way you have them.
    Are you seats still up on 2x4’s? FFR has told me they have engineering working on frame supports to raise the seat.
    I also swapped out my “too short” 5 point belts for their newer ones.
    So, I think they are working on our feedback.
    Ralph
  39. #159
    Nov 2012
    Tucson, AZ
    Yes still sitting on 2x4s. Do you have a picture of the new belts? Gave my 5points to a friend that needed them for a track day car so I canít exchange them with FFR.
    Deep Impact Blue
  40. #160
    Loveland, CO
    The belt are shown in Wallace18 posts. FFR said they were now supplying the newer belts with the kit, which doesn’t help you much.
    Ralph
