I have a question on my cam bolt installation. I started to clean one of the cam bolts up on the wire wheel before my installation and decided to test fit it on the frame. Started to tighten the nut by hand and it froze up way before getting tight.
I thought this was a bit odd, so I checked all of them and they all seem to “bottom out” well before hitting the offset washer. I then flipped the nut over to check the threads and it will barely even start on the bolt.
Am I missing washers for all my cam bolts, do you think I have the wrong ones, or am I missing something?
