Results 1 to 4 of 4
Thread: Bad MSD pickup module and dumb luck
    Southern WV
    It was 60 degrees here in Southern WV today so I just had to get the car out for a ride
    After about two hours I came back home and parked in front of the garage and came back out a few minutes later and the car wouldn’t start fuel but no spark changed the coil no luck Checked the resistance through the module and found a open circuit no change when then cranking the motor
    I have to count myself as lucky because it failed in the driveway
    I will order two pickups and keep one and some tools in the car in case it happens again
    Rick
    Senior Member bil1024's Avatar
    NY
    That sucks, wonder what caused it ?
    Southern WV
    I turned the key on to check some settings in the efi but didn’t start the motor that may have zapped the pickup module
    Live and learn I guess
    Member Frank Messina's Avatar
    Yorba Linda, CA
    That will fry it for sure. They have to discharge, that's the D part of CD ignition. Key on engine off causes the stored energy to cook the innards. Don't ask how I know.
    FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
