I had the same problem on the drivers side. Wound up adding a little aluminum extension to the splash guard to move the body out slightly then used a button head bolt for added clearance. I didn't notice any shims in your sidepipe connection. I needed two and that compounded my problem. McMaster Carr has a larger bulb seal that I also had to use just to close off the gaps around all the splash guards. Good luck.
