Results 1 to 16 of 16
Thread: Cooling fan temp start
    Senior Member broku518's Avatar
    Jupiter, FL
    Hello,
    I am checking the cooling fan today. If I understand this corectly, fan should start when certain temperature is reached.
    I have the fan wired like this.
    [url=https://flic.kr/p/226NQZj]
    I believe it should start automatically. I didn't install any manual switch.
    My sensor (two wires) looks like this.
    [url=https://flic.kr/p/23LUZqY]
    I could observe the gauge getting up 105 Celsius (so I stopped there and asking now
    No fan spinning.
    Aug 2017
    Southern WV
    My temp sensor for the fan only had one connection what happens when you ground the green fan sensor wire close to the fan
    Are you using an efi to control the fan
    My fan would run without the key turn on
    Rick
    Jupiter, FL
    Hi Itcheif.
    Thanks for the feedback. I turned the key (not started) and grounded the sensor, NO fan turning. I aslo checked the fuse, OK.
    Do I need to have the car running to check the fan?
    I wouldn't think so.
    Thanks.
    O'Fallon, MO
    You have to have a fan sensor, and a gauge sensor. That looks like a gauge sensor?
    Jupiter, FL
    Hm, so I need one sensor for the gauge and one for the fan to turn?
    Jupiter, FL
    Quote Originally Posted by Itchief View Post
    Rick
    Dang, I found one more sensor in my box. Single wire. I guess that needs to be hooked up someplace. I see one more green wire labeled fan switch...duh! I need to find place in manifold to install it.
    Now I feel stupid.
    Aug 2017
    Southern WV
    The two wire temp sensor is for the gauge and the single wire sensor is for the fan
    I didn’t catch the two wire part until after my first post
    Sorry
    Rick
    Jupiter, FL
    No worries. I found the single green wire in sending unit bundle, grounded and the fan is running.
    Its running even with the key removed. I thinking by design.
    Aug 2017
    Southern WV
    Good deal
    Quote Originally Posted by broku518 View Post
    The fan isn't always wired that way, it just means the fan relay is wired to an always hot, un-switched source, for power. Personally, I like that the fan runs on for a few minutes after stopping, but many builders prefer it not to.
    So what temp does the fan turn on, and turn off, now you have the proper sensor?
    Jupiter, FL
    Quote Originally Posted by AC Bill View Post
    It is labeled 180 degrees. I will mess with tomorrow.
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    I had to replace my thermostat housing with one that has a threaded port for the fan switch, it also turns off when i turn the ignition off.
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Jupiter, FL
    Quote Originally Posted by Walt View Post
    Walt
    Right, I checked and I don't have the thread either. I found a hole in manifold that I can use instead.
    Dec 2013
    Navasota, Texas
    Make sure you are putting in a place to get the correct temp. When you need it or it will overheat
    Jupiter, FL
    Right, I started questioning myself. I can see coolant inside of it. But still called and sent pic to Mike Forte. Since they build the engine.
    Thanks.
    Martin
    Vermilion,OH
    My sensor is in the manifold next to distributor. Turned on at 185F, shuts off at 163F. Temp actually rises a bit after shutting off to 201F. Fan runs about 20 mins after shutting off.
