Am I right in that the rear of the body (all 4 locations) should be mounted first? The rear bolt sleeves, the longer sleeve is on the inside of the trunk area, dictate how far rearward the body should be pulled? Any of the.is make sense? In other words do the bolt sleeves determine the correct distance rearward for the body? (The longer one is 3.75”, so is this the critical distance that has to be satisfied?)
I should mention that I’m doing the threaded coupler mod on the rear, so asking a different way... what should be distance from the end of the threaded coupler to the fiberglass?
As I read body mounting recommendations, this is the first step... as always, thanks in advance!
