trim at body where exhaust exits
I just mounted my exhaust. I'm using the FFR stock side pipes.
A few immediate questions.
Has anyone closed in the body hole with some sort of trim? I'm thinking the stock body hole is way larger than it needs to be I would like to trim it out and make it smaller at the same time. Does the heat from the exhaust bother the fiberglass that is close?
Where can I get this ceramic coated?
