Results 1 to 6 of 6
Thread: BluePrint Engines now selling add on parts! trick Ignition, fuel, and cooling parts!
    BluePrintEngines's Avatar
    Nov 2015
    Kearney, NE
    Hey Guys,
    We have taken the plunge to sell engine add on parts on our BluePrintEngines.com site!
    We have some pretty awesome distributor offerings, coils, fuel pumps, water pumps, etc.
    Some of you guys building your own engines may find a chance to do some business with us also!
    Check out the new sections and maybe try out a all black distributor or new fuel pump!!!
    Either click on the "Parts" tab as shown in the picture above. or go direct to a category as shown below. Let me know if you have any questions.
    https://blueprintengines.com/collections/distributors
    https://blueprintengines.com/collections/ignition-coils
    https://blueprintengines.com/collections/starters
    https://blueprintengines.com/collections/alternators
    https://blueprintengines.com/collect...ric-fuel-pumps
    https://blueprintengines.com/collect...ure-regulators
    https://blueprintengines.com/collections/water-pumps
    https://blueprintengines.com/collections/apparel
    Check out our crate engine offerings at www.factoryfiveengines.com
    Give us a call at 1.800.483.4263
    Nov 2015
    Kearney, NE
    Rotonda West Florida
    Normally, I believe "Cry once", but your price for a HEI Ford dizzy is hard to pass up. Do you have any dimensions for it? I have to keep it under a large air cleaner, and that is a big concern.
    Will use with FITech EFI so, it needs the tach output. Part # BPP302BL ? Will it work with a roller cam gear?
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by BluePrintEngines View Post
    So if someone buys the Sniper EFI and a motor at the same time will y'all do the dyno with the Sniper on the motor? Or does it take too much time to auto tune before it can be put on a dyno?
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Nov 2015
    Kearney, NE
    Quote Originally Posted by KenWilkinson View Post
    Wow, sorry for the long response on our part. missed this entirely.
    we have customers that have used the BPP302BL in the MKIV, but it is a full size GM cap, so pending your air cleaner type, you may run into clearance issues with that.
    What i would suggest is this one, you do run an external coil, but its still an HEI module. its MUCH shorter/smaller. We use them on our "bronco" engines, which have hood clearance, and air cleaner issues.
    https://blueprintengines.com/collect...-cap-bpp3021bl
    coils
    or even better... a pro-billet type. fully "ready to run" also
    https://blueprintengines.com/apps/om...3&type=product
    Nov 2015
    Kearney, NE
    Quote Originally Posted by TDSapp View Post
    Yes, any of our engines that ship with a sniper, are fully dyno tested, with THAT sniper unit.
    so any of the EFI engines on...
    or
    https://factoryfiveengines.com/
    are dyno tested, yes. (Even the long blocks with no intake/carb)
